> Wheel hub, Wheel hub play
RKramden
post Aug 12 2025, 05:03 PM
Finally putting the rear suspension back together and have noticed some play in both hubs. Not in and out, but more like rocking back and forth, side to side. Before I go any further, is this normal and will it go away when the axle hub is torqued down? BTW, these are new bearing, and seem to be seated all the way with the retainers installed. Any insight will be greatly appreciated
RKramden
post Aug 13 2025, 09:45 PM
Bearing was FAG from 914 Rubber, and went in tight with some med-heavy pulls on the all thread nut with steel angles on either side. I’ll be heading down to my FLAPS store to borrow the mega torque wrench this weekend. If that solves the wobble then it’s off to installing the engine. Thank you all for the input!!
- Lo-Fi Version Time is now: 16th August 2025 - 10:58 AM
