Joec |
Newbie ![]() Group: Members Posts: 26 Joined: 26-April 21 From: Delta, BC Member No.: 25,484 Region Association: None ![]() |
My car has been totally restored with 1 last problem which we can't seem to solve. We believe it is a shift rod adjustment problem but after a ton of time we can't figure it out. Reverse, 1st, 2nd, 3rd no problem, but regardless what we do no 4th or 5th. The transmission was rebuilt so assuming it was done correctly, all the bushings were replaced, the rod seems solid with no play. Could something be assembled wrong at the transmission? We have read all the different solutions and tried all to no avail, we have yet to see 4th or 5th working. Failing that, only solution is to send to a shop which most likely will have little experince with a 914 so who knows what they will do. Suggestions?
Shivers |
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,133 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California ![]() |
My car has been totally restored with 1 last problem which we can't seem to solve. We believe it is a shift rod adjustment problem but after a ton of time we can't figure it out. Reverse, 1st, 2nd, 3rd no problem, but regardless what we do no 4th or 5th. The transmission was rebuilt so assuming it was done correctly, all the bushings were replaced, the rod seems solid with no play. Could something be assembled wrong at the transmission? We have read all the different solutions and tried all to no avail, we have yet to see 4th or 5th working. Failing that, only solution is to send to a shop which most likely will have little experince with a 914 so who knows what they will do. Suggestions? ![]() Hi Joe. I do not see the year of the car. This does not always matter, people do trans conversions and swaps around here. But from 1973 on, the trans was different. The way it was set up to shift. And the way you adjust 4-5th back into the mix. Do you have a tail shift or a side shift? If you are not sure post up pictures Nice car. (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 3rd September 2025 - 09:25 PM |
