> Steering Wheel Shimmy, Slight vibration
Mowog4
post Aug 14 2025, 05:57 PM
I have a slight vibration in my steering wheel, it is very minor but noticeable. It does not get worse with speed, but I find it annoying. Every suspension piece on the front end of the car has been replaced, new struts, new wheel bearings, etc.. I thought, possibly it was a problem with flat spotting of tires, but new tires and wheels did not make a difference I see online there is a steering stabilizer, that is the only thing I haven’t changed down. Can anyone tell me what that does?
Thanks
Ed
mlindner
post Aug 15 2025, 08:10 PM
Mowog4, I replaced all suspension bushing, struts, brakes five years ago when my 914-6 GT Tribute made it back on the road after a 29 year nap. I did the very simple string alignment after ride hight, camber and caster and have put five thousand miles on each year. Car is smooth, never a vibration at any speed. As mentioned, bent rim, have you retorqued all the suspension nuts on every thing. Steering rack, ball joints, brake calipers, wheel bolts or nuts. Just check every thing, one to get rid of the vibration, two for your safety. Best, Mark
Mowog4   Steering Wheel Shimmy   Aug 14 2025, 05:57 PM
emerygt350   Have you had the wheel balance checked?   Aug 14 2025, 06:25 PM
Mowog4   Have you had the wheel balance checked? I have ...   Aug 14 2025, 07:10 PM
bkrantz   You can try on-car wheel balancing.   Aug 14 2025, 07:23 PM
mgp4591   How's your alignment? You've heard this b...   Aug 14 2025, 10:02 PM
Mowog4   How's your alignment? You've heard this ...   Aug 14 2025, 11:36 PM
Shivers   Do you have hub centric rings up front. Sometimes ...   Aug 15 2025, 05:07 AM
Jamie   Do you have hub centric rings up front. Sometimes...   Aug 15 2025, 07:22 AM
Superhawk996   Need more info: What speed range does it occur? ...   Aug 15 2025, 08:50 AM
Mowog4   See below:quote name='Superhawk996' date=...   Aug 15 2025, 09:36 AM
930cabman   are the wheel bearings adjusted correctly   Aug 15 2025, 10:17 AM
Superhawk996   You’re not going to like my answer. Without dr...   Aug 15 2025, 10:32 AM
Mowog4   Thanks for the input, I’ll find a road force bal...   Aug 15 2025, 10:52 AM
Superhawk996   I’m getting old. Here’s a new solution that p...   Aug 15 2025, 11:17 AM
Mowog4   I’m getting old. Here’s a new solution that ...   Aug 15 2025, 01:39 PM
rjames   It took me going to 3 different shops to find one ...   Aug 15 2025, 01:59 PM
Maury4   I have a slight vibration in my steering wheel, i...   Aug 15 2025, 03:27 PM
914sgofast2   Might be a long shot, buy are you certain that you...   Aug 15 2025, 03:31 PM
Mowog4   Might be a long shot, buy are you certain that yo...   Aug 15 2025, 05:26 PM
Front yard mechanic   Bent wheel or 2 my guess   Aug 15 2025, 04:55 PM
jim_hoyland   Been down a related road; now I only go to Alignme...   Aug 15 2025, 05:43 PM
Mowog4   It has been annoying, the place that aligned it is...   Aug 15 2025, 06:18 PM
mlindner   Mowog4, I replaced all suspension bushing, struts,...   Aug 15 2025, 08:10 PM
- Lo-Fi Version Time is now: 16th August 2025 - 02:10 PM
