Bruce Hinds |
V-8 madness ![]() ![]() ![]() Group: Members Posts: 751 Joined: 27-December 06 From: Port Orchard, WA Member No.: 7,391 Region Association: Pacific Northwest ![]() |
Everything else shifts like butter, but when I reach for first it's like the clutch is not even in. I've never had anything like this before.
I really don't use first much at all, big engine with lots of torque, so second is my starting gear, I only use first on rare occasions for something like steep driveways or a stop sign at the top of a hill. Thinking back about what I may have done which is usually the root cause of most of my problems . . . the only thing I can think of is that I had the back up light sender out to remove the male pins from the plug that had broken off in the sender. Could I have done something reinstalling the sender that could affect first? |
Shivers |
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,120 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California ![]() |
Everything else shifts like butter, but when I reach for first it's like the clutch is not even in. I've never had anything like this before. I really don't use first much at all, big engine with lots of torque, so second is my starting gear, I only use first on rare occasions for something like steep driveways or a stop sign at the top of a hill. Thinking back about what I may have done which is usually the root cause of most of my problems . . . the only thing I can think of is that I had the back up light sender out to remove the male pins from the plug that had broken off in the sender. Could I have done something reinstalling the sender that could affect first? Hi Bruce the actuator pin is between the trans shift rod and the electrical switch that controls the reverse lights. Not sure how it would happen, I’m no expert. But if it were me I’d Pull that pin, put the switch back in and try 1st gear. |
Bruce Hinds |
Everything else shifts like butter, but when I reach for first it's like the clutch is not even in. I've never had anything like this before. I really don't use first much at all, big engine with lots of torque, so second is my starting gear, I only use first on rare occasions for something like steep driveways or a stop sign at the top of a hill. Thinking back about what I may have done which is usually the root cause of most of my problems . . . the only thing I can think of is that I had the back up light sender out to remove the male pins from the plug that had broken off in the sender. Could I have done something reinstalling the sender that could affect first? Hi Bruce the actuator pin is between the trans shift rod and the electrical switch that controls the reverse lights. Not sure how it would happen, I’m no expert. But if it were me I’d Pull that pin, put the switch back in and try 1st gear. That would seem like the reasonable thing to do. Being unfamiliar with it, I just hope I didn't bend something putting it in. |
Shivers |
Everything else shifts like butter, but when I reach for first it's like the clutch is not even in. I've never had anything like this before. I really don't use first much at all, big engine with lots of torque, so second is my starting gear, I only use first on rare occasions for something like steep driveways or a stop sign at the top of a hill. Thinking back about what I may have done which is usually the root cause of most of my problems . . . the only thing I can think of is that I had the back up light sender out to remove the male pins from the plug that had broken off in the sender. Could I have done something reinstalling the sender that could affect first? Hi Bruce the actuator pin is between the trans shift rod and the electrical switch that controls the reverse lights. Not sure how it would happen, I’m no expert. But if it were me I’d Pull that pin, put the switch back in and try 1st gear. That would seem like the reasonable thing to do. Being unfamiliar with it, I just hope I didn't bend something putting it in. I do not know if it would make a difference, it is there for some reason, that C clip on the pin maybe it popped off. Something to look for. Good luck |
Lo-Fi Version | Time is now: 16th August 2025 - 02:10 PM |
