> Alignment Systems for 914?
bkrantz
post Aug 15 2025, 08:39 PM
Short version: what shop alignment systems work for 914s?
Longer version: My 1973 2.0 is almost stock, with standard fenders and 4 bolt Fuchs. The suspension is also near stock, with Bilsteins all around, stock (original) torsion bars up front, and 100 lb springs in the rear. I have 195/65-15 tires. Ride height is slightly lowered.
When I finished rebuilding the car I did a home alignment and then headed to the only local shop that has 914 experience (and positive recommendations). But after they had my car on their alignment rack for about 20 minutes, the tech came to tell me that he could not complete the job, because the rigs that mounts on the front wheels hit the fenders as he pivoted the wheels for getting caster. He spent a bit more time and measured F and R camber and toe, but then sent me home.
After that I did my own alignment as precisely as I could, with double and triple measurement. Al of this was in July and August of 2022, and I have been driving the car since then. It tracks well, and turns in easily--perhaps too easily. It seems very sensitive to small steering inputs at speed.
So I would like to see about getting a shop to take a look, but knowing what systems, new or old, will likely work will help.
Superhawk996
post Aug 16 2025, 06:06 AM
There is an enormous variation in how heads mount to the wheel / rim.
Since you don’t mention what they used, I’m guessing it was the old style heads with hooks and a rack type screw clamp that grabs the wheel rim lip. (IMG:style_emoticons/default/confused24.gif) Most shops have an assortment of head adapters & extensions that should allow them to extend heads outboard if they are hitting the body. Skill of the shop always supersedes how fancy their equipment may look.
Hunter Hawkeye heads that grab the tire should be able to be mounted by a tech that knows what he’s doing.
bkrantz   Alignment Systems for 914?   Aug 15 2025, 08:39 PM
Geezer914   I do my own using the string method and a camber g...   Aug 16 2025, 04:38 AM
930cabman   Short version: what shop alignment systems work f...   Aug 16 2025, 06:04 AM
Superhawk996   There is an enormous variation in how heads mount ...   Aug 16 2025, 06:06 AM
bkrantz   There is an enormous variation in how heads mount...   Aug 18 2025, 08:02 PM
ClayPerrine   I have a caster/camber gauge. And I have this fo...   Aug 16 2025, 01:50 PM
Superhawk996   Vintage 1960s Dunlop optical alignment gauge. Wo...   Aug 16 2025, 03:03 PM
ClayPerrine   Vintage 1960s Dunlop optical alignment gauge. W...   Aug 16 2025, 09:55 PM
SirAndy   So I would like to see about getting a shop to tak...   Aug 16 2025, 02:18 PM
bkrantz   So I would like to see about getting a shop to ta...   Aug 18 2025, 08:07 PM
Superhawk996   I need to convince myself to take a road trip to ...   Aug 19 2025, 09:14 AM
Artfrombama   Set mine with strings, jack stands and a magnetic ...   Aug 16 2025, 02:50 PM
Superhawk996   I’m going to put this here - just in case you w...   Aug 19 2025, 09:33 AM
yeahmag   I'm just starting to mess with Gyraline and it...   Aug 19 2025, 10:04 AM
Superhawk996   I'm just starting to mess with Gyraline and i...   Aug 19 2025, 10:23 AM
Jamie   I'm just starting to mess with Gyraline and i...   Aug 19 2025, 01:11 PM
Jamie   I'm just starting to mess with Gyraline and ...   Aug 19 2025, 01:12 PM
NARP74   This alignment system is supposed to be amazing. ...   Aug 19 2025, 11:34 AM
Chad911sc   I bought these two products from Amazon for a coup...   Aug 19 2025, 01:47 PM
Superhawk996   .Also when doing the castor I had to place two sh...   Aug 19 2025, 07:58 PM
Artfrombama   [quote name='Chad911sc' post='3220127' date='Aug ...   Aug 19 2025, 08:48 PM
yeahmag   For camber I just use a plumb bob and measure at t...   Aug 19 2025, 07:45 PM
- Lo-Fi Version Time is now: 22nd August 2025 - 08:07 PM
