> 914/6 Conversion Project, Identifying Engine Specs
Dugo16
post Aug 17 2025, 01:29 PM
I recently picked up a 914/6 conversion project car. I am in the process of trying to figure out what is in the engine without fully disassembling it since it appears to be in good shape. Engine is out of the car. Here is what I know so far.
- 1972 911T Case (911/07)
- 90mm Cylinders (90zn2)
- K1819n heads (one is a K1819g)
- 40IDS3C carbs
Trying to figure out what cam and crankshaft are in there.
Valve lift measurements below where measured with a dial gauge placed on the valve retainer.
- Intake lift .402
- Exhaust lift .376
Stock cam?
I figure the crank is a 66mm but it could be also be a 70.4mm from what I have read. Anyway to figure that out without disassembly?
Thanks in advance for any info. I appreciate the massive amount of knowledge the 914world community has!
-Doug
Dugo16
post Aug 18 2025, 11:43 AM
Moving on to the clutch and trans.
Clutch disc only shows wear on the outside half on the flywheel side. Is this normal? Normal for a new clutch disc?
Clutch disc measures at 9.7mm so thinking it is pretty new based on new ones being around 10mm. Flywheel surface looks good and appears to be flat using a small straight edge.
-Doug
Dugo16   914/6 Conversion Project   Aug 17 2025, 01:29 PM
brant   72 year would have come with a 70.4 crank I think...   Aug 17 2025, 01:32 PM
Dugo16   I recently picked up a 914/6 conversion project c...   Aug 17 2025, 01:47 PM
930cabman   :wttc: Great way to start off with a /6 conversi...   Aug 17 2025, 01:57 PM
infraredcalvin   I’m going through this on a heavily modified 3.4...   Aug 17 2025, 05:11 PM
Dugo16   If its a runner, get it tuned best you can, dyno ...   Aug 18 2025, 10:17 AM
burton73   :wttc: Please post some pictures Best Bob B   Aug 17 2025, 05:12 PM
targa72e   for early cranks 2 plugs on flywheel end is 66mm o...   Aug 17 2025, 10:41 PM
Dugo16   for early cranks 2 plugs on flywheel end is 66mm ...   Aug 18 2025, 10:14 AM
porschetub   for early cranks 2 plugs on flywheel end is 66mm...   Aug 18 2025, 05:49 PM
sixnotfour   [quote name='Dugo16' post='3219970' date='Aug 19 ...   Aug 18 2025, 06:46 PM
sixnotfour   https://www.drcamshafts.com/911profiles.htm   Aug 18 2025, 07:32 AM
sixnotfour   might want to price check IDS webers...   Aug 18 2025, 07:35 AM
brant   might want to price check IDS webers... I saw t...   Aug 18 2025, 09:21 AM
930cabman   might want to price check IDS webers... I saw ...   Aug 18 2025, 09:40 AM
Dugo16   [quote name='sixnotfour' post='32199...   Aug 18 2025, 10:22 AM
brant   That carb has one difference though that makes it ...   Aug 18 2025, 10:11 AM
Dugo16   Moving on to the clutch and trans. Clutch disc on...   Aug 18 2025, 11:43 AM
porschetub   Moving on to the clutch and trans. Clutch disc o...   Aug 18 2025, 06:11 PM
Dugo16   You can most likely reuse that clutch disk but no...   Aug 18 2025, 09:25 PM
DennisV   Trying to figure out what cam and crankshaft are ...   Aug 19 2025, 09:58 AM
- Lo-Fi Version Time is now: 22nd August 2025 - 08:07 PM
