| Kent |
Dec 20 2008, 11:39 PM
Newbie ![]() Group: Members Posts: 1 Joined: 20-December 08 From: Virginia Member No.: 9,865 Region Association: MidAtlantic Region |
Any helpfull hint on how th get the left /right adjustmet correct on the interior gear shift adjustment? I hve figured out forward and back.
| Jack Standz |
Aug 19 2025, 06:55 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 978 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None
There is an access hole towards the rear of the car on the same tunnel the shifter is bolted to. It's about maybe 18 inches from the shifter? You can get a vice grips on the shift rod through that access point.
And, remember to remove the vice grips after you make the adjustment. If you don't, you will wonder why you still can't shift into all gears. (IMG:style_emoticons/default/biggrin.gif) |
| Bruce Hinds |
Aug 19 2025, 08:43 PM
V-8 madness ![]() ![]() ![]() Group: Members Posts: 766 Joined: 27-December 06 From: Port Orchard, WA Member No.: 7,391 Region Association: Pacific Northwest |
There is an access hole towards the rear of the car on the same tunnel the shifter is bolted to. It's about maybe 18 inches from the shifter? You can get a vice grips on the shift rod through that access point. And, remember to remove the vice grips after you make the adjustment. If you don't, you will wonder why you still can't shift into all gears. (IMG:style_emoticons/default/biggrin.gif) Funny you should say that . . . last time I adjusted the clutch I'd left a small pair of vice grips on the clutch cable rod between the pulley and the throw out arm. I was under there recently and noticed something shiny. Stayed on for a few thousand miles. |
Kent Gear shift adjustment Dec 20 2008, 11:39 PM
Racer Chris With the trans in neutral, attach a bungee from th... Dec 21 2008, 12:06 AM
jim_hoyland
With the trans in neutral, attach a bungee from t... Feb 1 2014, 09:42 PM
Racer Chris
With the trans in neutral, attach a bungee from ... Feb 2 2014, 08:33 AM
Bruce Hinds
With the trans in neutral, attach a bungee from t... Aug 19 2025, 03:46 PM
Joe Ricard Damn I have been screwing around with "one sp... Dec 24 2008, 09:02 PM
cpavlenko :shock1: :shock1: :shock1: that is so simple, I... Mar 11 2014, 10:06 PM
Red72 A bit of a ressurection here, but I'm having s... May 18 2015, 05:57 PM
tomrev
A bit of a ressurection here, but I'm having ... May 18 2015, 06:44 PM
Red72
A bit of a ressurection here, but I'm having... May 21 2015, 12:01 PM
stugray Another trick I have learned (even if using Racer ... May 21 2015, 12:21 PM
Red72 So I'm now back to a point where I have first ... May 24 2015, 04:58 PM
Dr Evil Nope. The 4-5, 2-3 throws on a properly adjusted b... May 25 2015, 09:05 PM
Hine62 Where is the adjustment screw? I think R & 1st... Jun 8 2015, 01:11 PM
stugray
Where is the adjustment screw? I think R & 1s... Jun 8 2015, 05:06 PM
rgalla9146 Mark both pieces with a fine tip magic marker
put... Jun 8 2015, 06:37 PM
db9146 So mine is a tailshifter and I just finished repla... Jun 8 2015, 08:42 PM
Dave_Darling Sounds like you may need to adjust the lever over ... Jun 8 2015, 08:58 PM
RobW I use the put it wrong method, and then estimating... Jun 9 2015, 07:43 AM
Racer Chris
I use the put it wrong method, and then estimatin... Jun 9 2015, 08:48 AM
Dr Evil Put in 2nd. Disconnect shifter at rod (side shift)... Jun 9 2015, 07:42 PM
Bruce Hinds
Put in 2nd. Disconnect shifter at rod (side shift... Aug 19 2025, 08:48 PM
jdahl Need some help here, I've tried Dr. Evil and R... Dec 3 2016, 10:47 AM
Racer Chris
... and rotated spline by spline.
The splin... Dec 3 2016, 03:01 PM
SKL1 Get Chris' new front adjuster... just a satis... Dec 3 2016, 12:30 PM
Keith914 Check that nothing is preventing full left to righ... Dec 3 2016, 02:03 PM
Dave_Darling
Check that nothing is preventing full left to rig... Aug 19 2025, 07:07 PM
porschetub I continue to struggle with mine and think I'a... Dec 3 2016, 02:54 PM![]() ![]() |
Lo-Fi Version | Time is now: 11th November 2026 - 06:35 PM |
