914ltd |
Member ![]() ![]() Group: Members Posts: 245 Joined: 18-April 03 From: Peoria, IL Member No.: 581 Region Association: None ![]() ![]() |
The first one is almost dumb, OK, dumb. On the 1973 and 1974 front bumper. These blocks are located behind the front tits. Which way does the fat part of the rubber block set, up or down? I believe I have been installing them fat up but I don't remember if I researched it or assumed?
Second Q, I have a '74 with the foam rubber stock steering wheel. As many do, the foam part turns on the steel ring. Has someone injected glue inside the foam to fix this? Any other ways to remedy? Thanks, Brad Attached thumbnail(s) ![]() ![]() |
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,086 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
@914LTD
I friend told me to use epoxy diluted with acetone and injection with a hypodyermic needle. And I never noticed they had a taper. Learned something new after decades of taking cars apart. |
Lo-Fi Version | Time is now: 21st August 2025 - 10:32 AM |
