> cylinder head temp gauge, sensor removal
EJP914
post Aug 17 2025, 12:44 PM
How to get this out? Wires broken at the under spark plug loop.
Guess I could just cut it and pull it out, but how do I get the new one in?
If I loosen a bunch of the screws that hold the engine tin on, would that get me enough space to get the new sensor to the spark plug?
OR is there some better way to do this?
Thanks for the advice.
EdAttached Image
Olympic 914
post Aug 21 2025, 08:59 AM
you could just run the wire down through the same hole the spark plug goes in.
It is easy to put the sensor on the plug then feed it down into the hole.
I have not had a problem with the wire rubbing through on the edge of the tin. but a little extra shrink wrap at that point wouldn't hurt.
- Lo-Fi Version Time is now: 22nd August 2025 - 12:22 PM
