> Sudden strange starting issue, The plot thickens
emerygt350
post Aug 20 2025, 02:45 PM
The past two days, cold start took longer than normal. Cranked maybe 8 times before starting. This morning it took twice that, and now all of a sudden at the grocery store after starting just fine at my office (3 block drive, engine never even got warm). It will sounds like it's going to catch but doesn't. Definitely smell gas, but not gassy. More like spark issue. I checked the wires to the coil, all seemed fine. Have not done any work on the engine for weeks. Since it happened in a busy parking lot I couldn't tell if the pump was running. Got it started, drove home 3 blocks. Starts right up again no problem.
This isn't going to be cool at Watkins glen in two weeks. I need to figure this out.
I'm thinking it's wiring to the coil. God I hope it's not the fuel pump. Next time I will have to juice it with some fluid to see if it's fueling. I don't want to put my fuel pressure gauge back in there if I don't have to.
Superhawk996
post Aug 21 2025, 09:13 AM
CHT and grounds for the injectors are prime suspects.
Don’t you have some Bluetooth variable resistance stuff wired into the CHT circuit? Verify the integrity of anything that’s modified.
No mention of having tried starting fluid to confirm you have a fueling problem.
emerygt350
post Aug 21 2025, 09:23 AM
QUOTE(Superhawk996 @ Aug 21 2025, 09:13 AM) *
All of my crazy is out of the cht circuit. I will have to double check the connections at the resistor.
Couldn't make it to the store for starter fluid. That will have to wait for tomorrow.
3 User(s) are reading this topic (1 Guests and 0 Anonymous Users)
2 Members: 76-914, Superhawk996
- Lo-Fi Version Time is now: 21st August 2025 - 11:57 AM
