emerygt350 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,134 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States ![]() |
The past two days, cold start took longer than normal. Cranked maybe 8 times before starting. This morning it took twice that, and now all of a sudden at the grocery store after starting just fine at my office (3 block drive, engine never even got warm). It will sounds like it's going to catch but doesn't. Definitely smell gas, but not gassy. More like spark issue. I checked the wires to the coil, all seemed fine. Have not done any work on the engine for weeks. Since it happened in a busy parking lot I couldn't tell if the pump was running. Got it started, drove home 3 blocks. Starts right up again no problem.
This isn't going to be cool at Watkins glen in two weeks. I need to figure this out. I'm thinking it's wiring to the coil. God I hope it's not the fuel pump. Next time I will have to juice it with some fluid to see if it's fueling. I don't want to put my fuel pressure gauge back in there if I don't have to. |
Lockwodo |
Member ![]() ![]() Group: Members Posts: 225 Joined: 23-December 21 From: Santa Cruz, Californnia Member No.: 26,193 Region Association: Northern California ![]() ![]() |
The 123 ignition provides the trigger pulse to the injectors, have you verified that connector is tight?
Lo-Fi Version | Time is now: 21st August 2025 - 11:57 AM |
