FlacaProductions |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,000 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California ![]() ![]() |
Brought two of my 3 MPS back to L.A. from Indiana while I await the arrival of my LCR55A so that I could do some bench plotting and tuning only to find that neither one of the now holds any sort of a vacuum.
Both ran fine in the car before flight - just needed some adjustment. One has the factory plug replaced with a Tangerine model - the other is still factory sealed. Did being in the unpressurized cargo area in my checked baggage blow them both? That would really stink.... Brian |
FlacaProductions |
Well. It’s back together and it’s holding SOME vac now.
Like 20 seconds worth but that’s better than the NONE of before. I’m suspecting the rubber seal around the outside? As I first mentioned, the outer four bolts seemed a little looser than I thought they should be but this is the first time I’ve had one apart. |
Olympic 914 |
![]() ![]() ![]() Group: Members Posts: 1,748 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States ![]() ![]() |
Well. It’s back together and it’s holding SOME vac now. Like 20 seconds worth but that’s better than the NONE of before. I’m suspecting the rubber seal around the outside? As I first mentioned, the outer four bolts seemed a little looser than I thought they should be but this is the first time I’ve had one apart. There is no time, when it is running that the diaphragm is required to hold an absolute vacuum. It is constantly pulling vacuum and changing. Although many will disagree with this, IMHO a 20 sec leakdown should not or only minimally effect the running. |
JeffBowlsby |
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,014 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
QUOTE There is no time, when it is running that the diaphragm is required to hold an absolute vacuum. It is constantly pulling vacuum and changing. Although many will disagree with this, IMHO a 20 sec leakdown should not or only minimally effect the running. That broad statement is a bit misleading and factually incorrect Tom. Care to expound on your perspective for the audience? |
Lo-Fi Version | Time is now: 22nd August 2025 - 12:38 PM |
