> 1971 turn signal relay question, 1971 Turn signal relay
Mike1981
post Aug 21 2025, 05:03 PM
Hello Everyone.
Finally getting back to working on my 1971 914.
When I bought it the turn signals did not work.
The headlights and taillights work. (When key is in ignition and in on position)
I took it out for a ride, and parked it in my garage.
The turn signal stalk was left in the right turn position.
Later that night I checked on the car, and found the right turn signal was on steady.
(Only when key is off car not running)
So, both left and right turn signal light steady when key is off but not when key is on or car running.
Apparently the wiring is not broken.
Can someone help ID the relay for the turn signal flasher on this board its a 1971
If so, does anyone know where I could source one?
Thanks everyone...
dtmehall
post Aug 21 2025, 06:01 PM
leaving the turn signal arm to a right or left position and lighting the respective bulbs, is a feature.
does this behavior happen on the other side? have you checked all the bulbs?
Mike1981
post Aug 21 2025, 06:19 PM
QUOTE(dtmehall @ Aug 21 2025, 08:01 PM) *
OK it is dark out and I took another look.
The front and rear turn signals will turn on steady no blinking if the stalk is in the right or left turn position.
Now I just discovered I have no brake lights.
I'll start checking fuses for the taillights.
Does anyone know what relay controls the turn signal blinkers?
Mike1981   1971 turn signal relay question   Aug 21 2025, 05:03 PM
dtmehall   what do you mean by the 'right turn signal was...   Aug 21 2025, 05:49 PM
Mike1981   what do you mean by the 'right turn signal wa...   Aug 21 2025, 05:53 PM
dtmehall   leaving the turn signal arm to a right or left pos...   Aug 21 2025, 06:01 PM
Mike1981   leaving the turn signal arm to a right or left po...   Aug 21 2025, 06:19 PM
dtmehall   http://www.914world.com/bbs2/uploads/post-...-1330...   Aug 21 2025, 06:32 PM
Mike1981   http://www.914world.com/bbs2/uploads/post-...-133...   Aug 21 2025, 06:49 PM
Mike1981   [quote name='dtmehall' post='3220503' date='Aug 2...   Aug 21 2025, 07:28 PM
Spoke   I think you have some custom wiring going on with ...   Aug 21 2025, 08:32 PM
Mike1981   [quote name='Spoke' post='3220527...   Aug 22 2025, 06:16 AM
Mike1981   [quote name='Spoke' post='3220527...   Aug 22 2025, 06:18 AM
Spoke   Thanks but the pic you are referring to is not th...   Aug 22 2025, 06:38 AM
jim_hoyland   When key is in the off position and either left or...   Aug 22 2025, 06:05 AM
Mike1981   When key is in the off position and either left o...   Aug 22 2025, 06:19 AM
Mike1981   Hello Everyone Well, my life has finally settled ...   Nov 4 2025, 09:22 AM
Spoke   Not sure what that relay is. It doesn't have t...   Nov 4 2025, 09:54 AM
Mike1981   Not sure what that relay is. It doesn't have ...   Nov 4 2025, 10:34 AM
Mike1981   Not sure what that relay is. It doesn't have...   Nov 4 2025, 10:38 AM
Spoke   Great may I buy one from you please? Would I simp...   Nov 4 2025, 01:40 PM
Mike1981   [quote name='Mike1981' post='3231308' date='Nov 4...   Nov 4 2025, 03:20 PM
Superhawk996   The only thing I can add is the photo in post #1 w...   Nov 4 2025, 08:07 PM
2 User(s) are reading this topic (1 Guests and 0 Anonymous Users)
1 Members: Spoke
- Lo-Fi Version Time is now: 4th November 2025 - 09:01 PM
