| Mike1981 |
Aug 21 2025, 05:03 PM
Member ![]() ![]() Group: Members Posts: 264 Joined: 21-July 14 From: Phoenix Member No.: 17,663 Region Association: South East States |
Hello Everyone.
Finally getting back to working on my 1971 914. When I bought it the turn signals did not work. The headlights and taillights work. (When key is in ignition and in on position) I took it out for a ride, and parked it in my garage. The turn signal stalk was left in the right turn position. Later that night I checked on the car, and found the right turn signal was on steady. (Only when key is off car not running) So, both left and right turn signal light steady when key is off but not when key is on or car running. Apparently the wiring is not broken. Can someone help ID the relay for the turn signal flasher on this board its a 1971 If so, does anyone know where I could source one? Thanks everyone... Attached thumbnail(s) |
| Spoke |
Aug 21 2025, 08:32 PM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,266 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
I think you have some custom wiring going on with the turnsignals. There should be a flasher relay where the leftmost circle is and the floating can in the rightmost circle is a custom solution.
Looks like somebody did an end run by wiring in a different flasher relay instead of getting an OEM type. Pull that assembly out and install an EP26 LED-compatible flasher relay with C2 grounded. ![]() |
| Mike1981 |
Aug 22 2025, 06:18 AM
[quote name='Spoke' post='3220527' date='Aug 21 2025, 10:32 PM']
I think you have some custom wiring going on with the turnsignals. There should be a flasher relay where the leftmost circle is and the floating can in the rightmost circle is a custom solution. Looks like somebody did an end run by wiring in a different flasher relay instead of getting an OEM type. Pull that assembly out and install an EP26 LED-compatible flasher relay with C2 grounded. Thanks but the pic you are referring to is not the set up I Have it is in the pic above. |
Mike1981 1971 turn signal relay question Aug 21 2025, 05:03 PM
dtmehall what do you mean by the 'right turn signal was... Aug 21 2025, 05:49 PM
Mike1981
what do you mean by the 'right turn signal wa... Aug 21 2025, 05:53 PM
dtmehall leaving the turn signal arm to a right or left pos... Aug 21 2025, 06:01 PM
Mike1981
leaving the turn signal arm to a right or left po... Aug 21 2025, 06:19 PM
dtmehall http://www.914world.com/bbs2/uploads/post-...-1330... Aug 21 2025, 06:32 PM
Mike1981
http://www.914world.com/bbs2/uploads/post-...-133... Aug 21 2025, 06:49 PM
Mike1981
[quote name='dtmehall' post='3220503' date='Aug 2... Aug 21 2025, 07:28 PM
Mike1981 [quote name='Spoke' post='3220527... Aug 22 2025, 06:16 AM
Spoke
Thanks but the pic you are referring to is not th... Aug 22 2025, 06:38 AM
jim_hoyland When key is in the off position and either left or... Aug 22 2025, 06:05 AM
Mike1981
When key is in the off position and either left o... Aug 22 2025, 06:19 AM
Mike1981 Hello Everyone
Well, my life has finally settled ... Nov 4 2025, 09:22 AM
Spoke Not sure what that relay is. It doesn't have t... Nov 4 2025, 09:54 AM
Mike1981
Not sure what that relay is. It doesn't have ... Nov 4 2025, 10:34 AM
Mike1981
Not sure what that relay is. It doesn't have... Nov 4 2025, 10:38 AM
Spoke
Great may I buy one from you please? Would I simp... Nov 4 2025, 01:40 PM
Mike1981
[quote name='Mike1981' post='3231308' date='Nov 4... Nov 4 2025, 03:20 PM
Superhawk996 The only thing I can add is the photo in post #1 w... Nov 4 2025, 08:07 PM![]() ![]() |
Lo-Fi Version | Time is now: 4th November 2025 - 09:02 PM |
