torakki |
Member ![]() ![]() Group: Members Posts: 66 Joined: 5-October 18 From: Nor Cal Member No.: 22,545 Region Association: Northern California ![]() |
I'm trying to track down a temperature issue on our 2.0L, and have replaced the gauge and sender. Temp still goes to red (about 280F), within 10 minutes of driving. Temp is actually around 165F from a laser temp reader. Only thing I can think of is wiring.
Am I correct, when I see the wiring diagram showing the Oil temp indicator is the same as the sensor? The diagram shows an "indicator" and a "gauge". I want to run some external, new wires to see if there's a difference. Thanks for any knowledge. ![]() |
TRP |
Newbie ![]() Group: Members Posts: 32 Joined: 2-September 23 From: Morgan Hill, CA Member No.: 27,559 Region Association: None ![]() |
I was thinking the same thing that @bdstone914 noted, are you sure you have the right gauge/sending unit combo? I once had a set of 356 gauges in a speedster that read all wonky due to mismatched senders to the gauges.
Lo-Fi Version | Time is now: 28th August 2025 - 01:45 AM |
