> Ignition switch issues?, Cranks but won't run with key
trojanhorsepower
post Aug 23 2025, 06:40 PM
So my car starts fine when I turn on the ignition and run the starter with a remote start switch, but not when the key turns powers the starter? This makes me suspect that the ignition switch is turning off the ignition while in the crank position. Is this a common failure point of these switches? or should I be looking somewhere else?
'74 2l 4lcyl
FlacaProductions
post Aug 27 2025, 06:51 AM
Greetings - I know very little about the six setups in 914's but I have a 67 911 and have read on the 911S board that the Partsklassic CD boxes enjoy a less than stellar reputation over there.
Sorry for the generalization but it may be a path to check.
trojanhorsepower   Ignition switch issues?   Aug 23 2025, 06:40 PM
Franz_x   Have you checked what's happening with the sol...   Aug 24 2025, 04:25 AM
DC_neun_vierzehn   I had the same issue for a while. Drove me crazy. ...   Aug 24 2025, 07:32 AM
trojanhorsepower   Thanks guys, Maybe I don't understand, but the...   Aug 24 2025, 09:49 AM
barefoot   Sounds like your ignition switch is gone bad, do y...   Aug 24 2025, 11:47 AM
trojanhorsepower   No. I think you have to take off the knee bolster...   Aug 24 2025, 12:59 PM
barefoot   No. I think you have to take off the knee bolste...   Aug 25 2025, 07:46 AM
trojanhorsepower   Thanks!   Aug 25 2025, 04:11 PM
gereed75   I have the same problem but with a different twist...   Aug 26 2025, 06:56 AM
emerygt350   I have the same problem but with a different twis...   Aug 26 2025, 07:37 AM
gereed75   Thanks for taking the time to give it some thought...   Aug 26 2025, 07:44 AM
gereed75   Spent some time with the six wiring diagram tonigh...   Aug 26 2025, 09:46 PM
Dave_Darling   Is it the ignition that's the problem? Test, ...   Aug 26 2025, 11:10 PM
gereed75   Thanks Dave. I am running a Crane optical points...   Aug 27 2025, 05:42 AM
emerygt350   I have run across many cars that drop the coil aft...   Aug 27 2025, 06:32 AM
FlacaProductions   Greetings - I know very little about the six setup...   Aug 27 2025, 06:51 AM
gereed75   Thanks Emory. Not sure why that happens but the ...   Aug 27 2025, 08:25 AM
Dave_Darling   Test, don't guess. --DD   Aug 28 2025, 12:09 AM
- Lo-Fi Version Time is now: 28th August 2025 - 07:44 AM
