> Electrical Testing - No Engine
DennisV
post Aug 27 2025, 09:06 PM
Will I do any damage if I drop a battery in a car that has no engine or transmission? I'd like to test the electrical system (i.e., lights, dash, horn, etc.)
Are there any cables, wires, or fuses that I would need to remove or tape off before connecting the battery? The engine harness is also currently out.
I realize without the generator, there will be nothing to charge the battery. I will get a battery tender.
Thank you.
P.S. I read that this Optima Redtop 35 was recommended, but their online fitment tool doesn't agree. In fact, it says "OPTIMA DOES NOT CURRENTLY OFFER A BATTERY IN YOUR SIZE" when I enter 1970 Porsche 914-6.
Superhawk996
post Aug 27 2025, 11:00 PM
Would be far wiser to do it using a current limiting power supply. That way if you have an unanticipated short somewhere, you’re not dependent on a smattering of fuses to protect the wiring.
If you don’t want to spring for a cheap power supply, you could use the battery but I’d fuse the battery down to something on the order of 5 amps at the initial connection. You can upsize the fuse gradually as you prove out wiring and add load.
A unfused battery is capable of smoking wiring before you can even disconnect it.
DennisV
post Aug 28 2025, 06:54 AM
QUOTE(Superhawk996 @ Aug 27 2025, 10:00 PM) *
Good idea. I see I can get a 12 AWG holder with blade fuses for $4. Cheap insurance.
- Lo-Fi Version Time is now: 18th September 2025 - 01:53 PM
