> No Alt. light after start up but battery not topping off ..
Literati914
post Aug 9 2025, 10:35 AM
My battery was bought last month.. Alternator light comes on with the key on, but goes out at start up. Battery keeps running low and eventually won't start the car. Does this point to anything usual - VR maybe?
Literati914
post Aug 27 2025, 06:36 PM
Also, I just found the following break in the wire casing of the brown wire at the relay plug! - think that’s enough to cause my charging issues?
Superhawk996
post Aug 28 2025, 11:38 AM
QUOTE(Literati914 @ Aug 27 2025, 08:36 PM) *
Yeah!
The color of the copper underneath doesn’t look healthy. That wire (D-) brings ground up from the alternator to the voltage regulator. Without a good ground reference the voltage regulator cannot operate properly.
There is no guarantee this is your only problem. Per previous posts you also had 0.8v or more drop between D+ and the battery positive post.
Kelty360 has it right - address root cause(s) of voltage drops rather than adding grounds everywhere hoping for a fix.
If you want to measure the voltage drop in that cracked wire:
Use meter (milli-volts scale).
Engine running - voltage regulator plugged in. That alternator connected - plugged into the relay board.
Meter ground lead to alternator case. Where the lead is placed matters. Measuring to the pivot bolt or fan should will not give an accurate measurement.
Meter positive lead to the spade connector on the cracked wire, of that 3 pin alternator connector. You have to back probe that connector while it’s plugged into the relay board.
Reading should be 0.0v
Anything higher than that indicates corrosion in the wiring and a voltage drop across that wire.
Literati914   No Alt. light after start up but battery not topping off ..   Aug 9 2025, 10:35 AM
GregAmy   Does this point to anything usual - VR maybe? What...   Aug 9 2025, 10:44 AM
fixer34   Could be several things but VR is a likely suspect...   Aug 9 2025, 11:24 AM
TheCabinetmaker   Check the belt tension   Aug 9 2025, 12:04 PM
Literati914   Does this point to anything usual - VR maybe? Wha...   Aug 10 2025, 07:14 PM
GregAmy   update - the bulb is not blown. I can get it to l...   Aug 10 2025, 08:13 PM
Lockwodo   [quote name='GregAmy' post='3218602' date='Aug 9 ...   Aug 10 2025, 09:41 PM
dtmehall   I experienced similar symptoms about 4 years ago. ...   Aug 10 2025, 07:24 PM
Spoke   There is a quick test you can do on the alternator...   Aug 10 2025, 07:26 PM
Literati914   just noticed that my alt bulb has blown after tigh...   Aug 10 2025, 07:26 PM
Literati914   update - the bulb is not blown. I can get it to li...   Aug 10 2025, 07:42 PM
Literati914   Alt light with ground provided by test light… li...   Aug 10 2025, 07:54 PM
Literati914   You can see the rat’s nest of wires here   Aug 10 2025, 07:55 PM
Literati914   update - the bulb is not blown. I can get it to ...   Aug 10 2025, 08:39 PM
Literati914   [quote name='Literati914' post='3218779' date='A...   Aug 10 2025, 09:17 PM
Spoke   removing the alt plug at the relay board in order...   Aug 11 2025, 05:30 AM
Literati914   If the battery voltage, measured at the terminals...   Aug 11 2025, 01:35 PM
Lockwodo   If the battery voltage, measured at the terminal...   Aug 12 2025, 12:04 PM
Literati914   .. If you unplugged the alternator please plug it...   Aug 11 2025, 02:32 PM
Spoke   .. If you unplugged the alternator please plug i...   Aug 11 2025, 04:02 PM
Literati914   .. What is the battery voltage at idle? Positive ...   Aug 11 2025, 04:27 PM
Spoke   .. What is the battery voltage at idle? Positive...   Aug 11 2025, 06:41 PM
Literati914   I did the test - jumper wire between D+/DF (with V...   Aug 11 2025, 07:06 PM
Literati914   .. Can you measure the battery voltage and D+ wi...   Aug 11 2025, 07:15 PM
Spoke   .. Can you measure the battery voltage and D+ w...   Aug 11 2025, 11:34 PM
GregAmy   I tend to agree that it's a diode, which is a ...   Aug 12 2025, 07:50 AM
Superhawk996   I’ve been reluctant to chime in . . . . Cause Iâ...   Aug 12 2025, 09:14 AM
GregAmy   ^^^ Good points.   Aug 12 2025, 09:58 AM
Literati914   Still dealing with the problem of alternator not c...   Aug 27 2025, 04:17 PM
emerygt350   I have really enjoyed my negative terminal to the ...   Aug 27 2025, 04:59 PM
Literati914   I've already installed something similar - top...   Aug 27 2025, 05:18 PM
Literati914   Also, I just found the following break in the wire...   Aug 27 2025, 06:36 PM
Superhawk996   Also, I just found the following break in the wir...   Aug 28 2025, 11:38 AM
emerygt350   Might be, however I wouldn't rely on the 50 ye...   Aug 27 2025, 07:50 PM
VaccaRabite   It does not take much of a voltage drop to dischar...   Aug 28 2025, 10:02 AM
Literati914   OK then, the plan is to run a wire off the lower p...   Aug 28 2025, 10:24 AM
KELTY360   Beware adding two fixes at once. The added ground ...   Aug 28 2025, 11:02 AM
Literati914   If you want to measure the voltage drop in that c...   Aug 29 2025, 11:50 AM
Superhawk996   Probably normal :confused: but would that be an...   Aug 29 2025, 07:30 PM
Literati914   .. If there is any doubt in your mind about paras...   Aug 29 2025, 08:50 PM
- Lo-Fi Version Time is now: 29th August 2025 - 11:16 PM
