> Piece of hard plastic between no. 2 cilinder and engine tin, How can I best remove it?
Marcel Aircooled
post Aug 28 2025, 12:58 PM
Region Association: Europe
When checking my spark plugs I found a loose piece of hard plastic inbetween the no. 2 cilinder and the engine tin. It turns out to be one of the alternator inspection covers. I have no idea how it got there and unfortunately it is just too big to fit through the spark plug hole in the engine tin so I cannot get it out of there. I found the plastic piece a year ago and only just recently found out it is one of the inspection covers and it does not seem to do any harm where it is now but it just bugs me knowing it is there. Does anyone have any suggestions on how to get it out from under the engine tin without removing the engine? Would it be easy to remove the engine tin only where the plastic piece is located? Or any suggestions how to break or bend the plastic piece?
Here's a picture (sorry for the poor quality) of the piece seen through the spark plug hole
This is an example picture of the part I am talking about
Marcel Aircooled
post Aug 28 2025, 02:30 PM
Thanks Pat. I can grab it with a pair of pliers but then there is no space left to cut or break it easily and I am a bit afraid to damage the engine tin. Also not sure what happens if I do break it and there are pieces left behind. Might give it a try though unless someone comes up with a brilliant suggestion (IMG:style_emoticons/default/wink.gif)
- Lo-Fi Version Time is now: 29th August 2025 - 11:16 PM
