914Wes |
Newbie ![]() Group: Members Posts: 41 Joined: 9-March 22 From: SO CAL Member No.: 26,388 Region Association: Southern California ![]() |
I found a stash of ceramic fuses in 8, 16, and 25 amp. About 2-300 of each are available. I was wondering what do you guys figure spare fuses are worth now that they are not being made in ceramic anymore. How would you guys like to purchase spares? I could make them into complete set of 12 for the fuse panel, 1 of each needed depending on year, or perhaps just small 5 packs like the 911 did it with 3 x 8 amp fuses, 1x 16 amp, 1 x 25 amp? Obviously not trying to do this to get rich but would need to make it worth my time to repack/ship fuses.
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,107 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
I have in an emergency wrapped a burned out fuse in aluminum foil to get going.
Spoke |
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,238 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None ![]() ![]() |
I have in an emergency wrapped a burned out fuse in aluminum foil to get going. Now there's a guy with his feet on the ground. (IMG:style_emoticons/default/beerchug.gif) I'm missing the point of using ceramic fuses. I drive my 914 all the time and can't remember the last time I had to replace a burned fuse. Attached thumbnail(s) ![]() |
914Wes |
I have in an emergency wrapped a burned out fuse in aluminum foil to get going. Now there's a guy with his feet on the ground. (IMG:style_emoticons/default/beerchug.gif) I'm missing the point of using ceramic fuses. I drive my 914 all the time and can't remember the last time I had to replace a burned fuse. If you read the details they are plastic fuses offered for cheap. They often melt and lead to issues and often have a cheap aluminum conductor. I would be offering NOS fuses from 70s. |
JamesM |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,130 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region ![]() |
Now there's a guy with his feet on the ground. (IMG:style_emoticons/default/beerchug.gif) I'm missing the point of using ceramic fuses. I drive my 914 all the time and can't remember the last time I had to replace a burned fuse. If you read the details they are plastic fuses offered for cheap. They often melt and lead to issues and often have a cheap aluminum conductor. I would be offering NOS fuses from 70s. I guess im still confused as well? https://memotronics.com/5-fuses-bullet-cera...losser-germany/ https://www.napaonline.com/en/p/ATMN171214?...ppid=ATMN171211 Littlefuse datasheets for their GBC fuses list them as being ceramic/heat resistant bodies as well? https://www.littelfuse.com/products/fuses-o...ducts-fuses/gbc |
wonkipop |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,007 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille ![]() ![]() |
Now there's a guy with his feet on the ground. (IMG:style_emoticons/default/beerchug.gif) I'm missing the point of using ceramic fuses. I drive my 914 all the time and can't remember the last time I had to replace a burned fuse. If you read the details they are plastic fuses offered for cheap. They often melt and lead to issues and often have a cheap aluminum conductor. I would be offering NOS fuses from 70s. I guess im still confused as well? https://memotronics.com/5-fuses-bullet-cera...losser-germany/ https://www.napaonline.com/en/p/ATMN171214?...ppid=ATMN171211 Littlefuse datasheets for their GBC fuses list them as being ceramic/heat resistant bodies as well? https://www.littelfuse.com/products/fuses-o...ducts-fuses/gbc first link looks interesting. do appear to be ceramic. my guess - older stock. or could even be an older image - but you buy em and plastic turns up. the big giveaway on the ceramic fuses is that the red ones in particular are a dark red when ceramic. the thermoplastic are a much brighter less dark red. the whites also look a starker white when plastic. probably worth getting a pack from that first link to see what happens. a lot of advertisers have older images, but the stock they are selling is whats available now. which is not ceramic body and does not have brass/copper filament. look closer at little fuse datasheets. just says heat resistant body. doesn't say ceramic. all the plastic body fuses are marketed as heat resistant thermoplastic. maybe some are. some are definitely not. picture on data sheet seems to show aluminium filament. i suspect those fuses are the newer stock and a bit inferior. |
Lo-Fi Version | Time is now: 3rd September 2025 - 06:12 PM |
