914Wes |
Newbie ![]() Group: Members Posts: 41 Joined: 9-March 22 From: SO CAL Member No.: 26,388 Region Association: Southern California ![]() |
I found a stash of ceramic fuses in 8, 16, and 25 amp. About 2-300 of each are available. I was wondering what do you guys figure spare fuses are worth now that they are not being made in ceramic anymore. How would you guys like to purchase spares? I could make them into complete set of 12 for the fuse panel, 1 of each needed depending on year, or perhaps just small 5 packs like the 911 did it with 3 x 8 amp fuses, 1x 16 amp, 1 x 25 amp? Obviously not trying to do this to get rich but would need to make it worth my time to repack/ship fuses.
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,107 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
I have in an emergency wrapped a burned out fuse in aluminum foil to get going.
Spoke |
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,238 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None ![]() ![]() |
I have in an emergency wrapped a burned out fuse in aluminum foil to get going. Now there's a guy with his feet on the ground. (IMG:style_emoticons/default/beerchug.gif) I'm missing the point of using ceramic fuses. I drive my 914 all the time and can't remember the last time I had to replace a burned fuse. Attached thumbnail(s) ![]() |
914Wes |
I have in an emergency wrapped a burned out fuse in aluminum foil to get going. Now there's a guy with his feet on the ground. (IMG:style_emoticons/default/beerchug.gif) I'm missing the point of using ceramic fuses. I drive my 914 all the time and can't remember the last time I had to replace a burned fuse. If you read the details they are plastic fuses offered for cheap. They often melt and lead to issues and often have a cheap aluminum conductor. I would be offering NOS fuses from 70s. |
JamesM |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,130 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region ![]() |
Now there's a guy with his feet on the ground. (IMG:style_emoticons/default/beerchug.gif) I'm missing the point of using ceramic fuses. I drive my 914 all the time and can't remember the last time I had to replace a burned fuse. If you read the details they are plastic fuses offered for cheap. They often melt and lead to issues and often have a cheap aluminum conductor. I would be offering NOS fuses from 70s. I guess im still confused as well? https://memotronics.com/5-fuses-bullet-cera...losser-germany/ https://www.napaonline.com/en/p/ATMN171214?...ppid=ATMN171211 Littlefuse datasheets for their GBC fuses list them as being ceramic/heat resistant bodies as well? https://www.littelfuse.com/products/fuses-o...ducts-fuses/gbc |
bdstone914 |
@JamesM
' date='Aug 31 2025, 03:12 PM' post='3222092'] @914Wes ' post='3222059' date='Aug 31 2025, 10:27 AM'] [quote name. @Spoke . ' post='3222025' date='Aug 31 2025, 06:52 AM'] Now there's a guy with his feet on the ground. (IMG:style_emoticons/default/beerchug.gif) I'm missing the point of using ceramic fuses. I drive my 914 all the time and can't remember the last time I had to replace a burned fuse. [/quote] If you read the details they are plastic fuses offered for cheap. They often melt and lead to issues and often have a cheap aluminum conductor. I would be offering NOS fuses from 70s. [/quote] I guess im still confused as well? https://memotronics.com/5-fuses-bullet-cera...losser-germany/ https://www.napaonline.com/en/p/ATMN171214?...ppid=ATMN171211 Littlefuse datasheets for their GBC fuses list them as being ceramic/heat resistant bodies as well? https://www.littelfuse.com/products/fuses-o...ducts-fuses/gbc [/quote] These old stock Littlefuse pack were ceramic with aluminum filaments Attached thumbnail(s) ![]() |
fixer34 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,330 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest ![]() ![]() |
[quote name='bdstone914' date='Aug 31 2025, 10:46 PM' post='3222146']
@JamesM ' date='Aug 31 2025, 03:12 PM' post='3222092'] @914Wes ' post='3222059' date='Aug 31 2025, 10:27 AM'] [quote name. @Spoke . ' post='3222025' date='Aug 31 2025, 06:52 AM'] Now there's a guy with his feet on the ground. (IMG:style_emoticons/default/beerchug.gif) I'm missing the point of using ceramic fuses. I drive my 914 all the time and can't remember the last time I had to replace a burned fuse. [/quote] If you read the details they are plastic fuses offered for cheap. They often melt and lead to issues and often have a cheap aluminum conductor. I would be offering NOS fuses from 70s. [/quote] I guess im still confused as well? https://memotronics.com/5-fuses-bullet-cera...losser-germany/ https://www.napaonline.com/en/p/ATMN171214?...ppid=ATMN171211 Littlefuse datasheets for their GBC fuses list them as being ceramic/heat resistant bodies as well? https://www.littelfuse.com/products/fuses-o...ducts-fuses/gbc [/quote] These old stock Littlefuse pack were ceramic with aluminum filaments [/quote] \ Definately old stock. Littlefuse hasn't been in Des Plaines in well over 20 yrs-building was demolished. I have a box (newer, but still 15+ yrs old) of GBC 16 red fuses, they appear to be plastic. I also found stashed away some GBC8 glass enclosed torpedo fuses. They are a little shorter though, probably 30+ years old. |
Lo-Fi Version | Time is now: 3rd September 2025 - 06:12 PM |
