DennisV |
Senior Member ![]() ![]() ![]() Group: Members Posts: 698 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California ![]() ![]() |
I have newly refurbished brake calipers that I am trying to install for the first time. New rotors and pads too. One of the 8 pistons will not compress sufficiently to allow me to the install the brake pad on that side. I have:
* Swapped brake pads * Removed the caliper from the car worked on it on the bench * Attempted to compress the piston with quick-action clamp * Backed off the adjustment screw I will of course call the vendor, but that puts me two days behind. I'm hoping for something obvious that I'm missing... Original 914-6 calipers if it matters. Thanks. ![]() |
Superhawk996 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,360 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch ![]() ![]() |
The adjuster should pull the piston in.
I’m going to attach the PMB video just so you have clarity on what the internals are https://www.youtube.com/watch?v=dm_DnizKOZM?si=Ku4c6ZRuVEYbtXHu There is an outside chance the adjuster mechanism wasn’t full seated into the piston. If you’re convinced the adjuster is backed all the way out and no longer pulling the piston in, you might want to be a little more aggressive with the clamp and see if you can push the piston back the rest of the way. See time stamp 27:00 or so to see what I’m talking about. |
fixer34 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,330 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest ![]() ![]() |
The adjuster should pull the piston in. I’m going to attach the PMB video just so you have clarity on what the internals are https://www.youtube.com/watch?v=dm_DnizKOZM?si=Ku4c6ZRuVEYbtXHu There is an outside chance the adjuster mechanism wasn’t full seated into the piston. If you’re convinced the adjuster is backed all the way out and no longer pulling the piston in, you might want to be a little more aggressive with the clamp and see if you can push the piston back the rest of the way. See time stamp 27:00 or so to see what I’m talking about. Actually, I don't think the adjuster retracts the piston, it is one-way only. |
Lo-Fi Version | Time is now: 3rd September 2025 - 06:14 PM |
