Thunderchief |
Member ![]() ![]() Group: Members Posts: 182 Joined: 12-August 19 From: Pasadena, CA. Member No.: 23,365 Region Association: Southern California ![]() |
My shift rod linkage cover has a crack and is leaking. It looks like I'll have to disconnect the rear linkage to change it out? Is that difficult to do? Also, which lubricant and how much do I use when I do? Thanks as always.
Stratfink |
Member ![]() ![]() Group: Members Posts: 83 Joined: 27-December 21 From: SoCal Member No.: 26,198 Region Association: Southern California ![]() ![]() |
I had the same issue and replaced the seal and cover earlier this year. I was doing the trans output shaft seals and had already drained the gear oil so it was an ideal time to tackle this. I was new to the 914 about 3 years ago and was able to do this on my own.
The experts here recommended a couple of other things not yet mentioned. 1. Replace the cone screws at each end of the shift rod - they have a nylon patch lock that gets run in with usage. 2. Because you are pulling the console as 914werke mentioned there is another o-ring seal that goes between the console and trans that can be replaced at this time. A little scary pulling the console out of the trans but it went back in and reengaged without issue. I also bought the self lubricating bronze bushing from 914werke to install where the rod enters the console but found a PO had already replaced the original nylon/plastic one already. Unfortunately I don’t have many pics but what I have is below. Cracked cover and new one (I think from PMB) ![]() View of console after the shift rod was removed ![]() Reassembled with new cone screw ![]() Hope this helps - there was good info in other threads and in the Haynes manual too… Cheers - Joe |
Lo-Fi Version | Time is now: 3rd September 2025 - 05:46 PM |
