> Ceramic fuses, What are they worth to ya?
How much should ceramic fuses cost each?
Price preference for NLA ceramic fuses per fuse sell price
$1 each (not profitable) [ 2 ] ** [25.00%]
$2 each [ 3 ] ** [37.50%]
$3 each [ 1 ] ** [12.50%]
$4 each [ 1 ] ** [12.50%]
$5 each [ 0 ] ** [0.00%]
$6+ each [ 1 ] ** [12.50%]
Total Votes: 8
Guests cannot vote
914Wes
post Aug 30 2025, 07:24 PM
I found a stash of ceramic fuses in 8, 16, and 25 amp. About 2-300 of each are available. I was wondering what do you guys figure spare fuses are worth now that they are not being made in ceramic anymore. How would you guys like to purchase spares? I could make them into complete set of 12 for the fuse panel, 1 of each needed depending on year, or perhaps just small 5 packs like the 911 did it with 3 x 8 amp fuses, 1x 16 amp, 1 x 25 amp? Obviously not trying to do this to get rich but would need to make it worth my time to repack/ship fuses.
bdstone914
post Aug 31 2025, 06:34 AM
bdstone914
I have in an emergency wrapped a burned out fuse in aluminum foil to get going.
Spoke
post Aug 31 2025, 07:52 AM
Jerry
QUOTE(bdstone914 @ Aug 31 2025, 08:34 AM) *
Now there's a guy with his feet on the ground. (IMG:style_emoticons/default/beerchug.gif)
I'm missing the point of using ceramic fuses. I drive my 914 all the time and can't remember the last time I had to replace a burned fuse.
914Wes
post Aug 31 2025, 12:27 PM
QUOTE(Spoke @ Aug 31 2025, 06:52 AM) *
If you read the details they are plastic fuses offered for cheap. They often melt and lead to issues and often have a cheap aluminum conductor. I would be offering NOS fuses from 70s.
JamesM
post Aug 31 2025, 04:12 PM
QUOTE(914Wes @ Aug 31 2025, 10:27 AM) *
I guess im still confused as well?
https://memotronics.com/5-fuses-bullet-cera...losser-germany/
https://www.napaonline.com/en/p/ATMN171214?...ppid=ATMN171211
Littlefuse datasheets for their GBC fuses list them as being ceramic/heat resistant bodies as well?
https://www.littelfuse.com/products/fuses-o...ducts-fuses/gbc
wonkipop
post Aug 31 2025, 04:34 PM
QUOTE(JamesM @ Aug 31 2025, 04:12 PM) *
first link looks interesting. do appear to be ceramic.
my guess - older stock.
or could even be an older image - but you buy em and plastic turns up.
the big giveaway on the ceramic fuses is that the red ones in particular are a dark red when ceramic. the thermoplastic are a much brighter less dark red. the whites also look a starker white when plastic.
probably worth getting a pack from that first link to see what happens.
a lot of advertisers have older images, but the stock they are selling is whats available now. which is not ceramic body and does not have brass/copper filament.
look closer at little fuse datasheets. just says heat resistant body. doesn't say ceramic.
all the plastic body fuses are marketed as heat resistant thermoplastic. maybe some are. some are definitely not. picture on data sheet seems to show aluminium filament.
i suspect those fuses are the newer stock and a bit inferior.
JamesM
post Aug 31 2025, 10:17 PM
QUOTE(wonkipop @ Aug 31 2025, 02:34 PM) *
Littlefuse calls them ceramic in their product description for them so (IMG:style_emoticons/default/confused24.gif)
Objectively, what makes a fuse inferior anyways? Popping before its supposed to? Not popping when its supposed to?
Its a fuse, they are not to complicated. Ceramic or not if its getting hot enough to melt anything without popping an 8 amp fuse I suspect you have other issues/high resistance at connections adjacent to the fuse itself.
wonkipop
post Sep 1 2025, 01:17 AM
QUOTE(JamesM @ Aug 31 2025, 10:17 PM) *
not popping when its supposed to.
some of the heat that is supposed to go into severing the filament is absorbed by the core described loosely as heat resistant thermoplastic. delays the fuse breaking.
fuse hangs on. damage to components or wiring the fuse is designed to protect occurs.
best case scenario is plastic fuse distorts and drops out of holders. worst case it stays in there and plastic keeps absorbing heat while filament maintains integrity.
ceramic is more than heat resistant. its an extremely good insulator and non conductor.
in this application i wouid go so far as to describe it as inert.
you are correct. the fuses are remarkably simple - in original form and in original materials. i would not be so confident describing the copy as being as simple.
JamesM
post Sep 1 2025, 10:37 AM
QUOTE(wonkipop @ Aug 31 2025, 11:17 PM) *
Then that would be a real problem if what they are selling as an 8amp fuse isn't actually an 8amp fuse.
I would be somewhat surprised if that is the case with the littlefuse part given fuses are sort of their thing. Cheap Chinese knockoffs not so much as their thing is making parts that look sort of like an original part but don't actually do anything.
It would be worth some real testing to see what current the plastic fuses pop at, but I still suspect anyone melting anything has other electrical issues. Specifically resistance at the connections around the fuse (either the fuse terminal or the spade connector) being higher than the resistance of the fuse element causing heat to be generated outside the fuse element and transferring to the body. Yes a proper ceramic fuse would be added insurance against this, but that doesn't fix the underlying issue.
This is all just assumption though, someone would need to actually test the fuse to know.
Two things:
1. Run more than 8 amps through one to see if (and at what amperage) it pops.
2. Run less than 8 amps though it for an extended period and see if it melts.
If those 2 pass than anyone melting fuses in their car has other issues and popping in a ceramic fuse just means they are more likely to melt their wire insulation instead.
I have some of the littlefuse parts coming to the shop. while I don't have a way to accurately load test them at the moment ill check out the fuse bodies and see what sort of heat they take.
Superhawk996
post Sep 1 2025, 11:21 AM
QUOTE(JamesM @ Sep 1 2025, 12:37 PM) *
Two things:
(IMG:style_emoticons/default/agree.gif) Stop making sense. (IMG:style_emoticons/default/lol-2.gif) Don’t wreck the magic of ewektwicity. (IMG:style_emoticons/default/beerchug.gif)
JamesM
post Sep 2 2025, 10:29 PM
QUOTE(Superhawk996 @ Sep 1 2025, 09:21 AM) *
Stop making sense.
I refuse! (IMG:style_emoticons/default/biggrin.gif)
Grabbed one of the brand new Littlefuse GBCs from one of the standard electronic supply chains and gave it to my assistant Beavis for some destructive testing.
@wonkipop Im no materials scientist, but I don't think these are plastic.
Knowing we were between the temperature of burning butane and the melting point of aluminum id estimate we tested to somewhere in the 1500 degree ballpark, aka mildly warmer than you want your fuse panel to ever be. And we cooked it for a good while.
ZERO deformation, zero burning, zero melting (other than the element) only real change to the body funny enough (other than adding a nice carbon coating) was the discoloration of the more vibrant red body to looking like the faded light pink of one of the 50 year old originals. (you can see a bit of it if you zoom in) Makes me wonder if the color of the original fuses isnt actually the original color but is the color of them oxidized for 50 years.
Sure if you get a cheap knock off plastic pill intended to look like a fuse you may have some issues, but if you buy an actual fuse from an actual fuse manufacturer I suspect you might be fine. But you do you.
Vendor says the factory has 4700 of the 8 amp in stock currently so we should be good for the next couple weeks at least.
914Wes   Ceramic fuses   Aug 30 2025, 07:24 PM
Superhawk996   What no $18/fuse option :rotfl:   Aug 30 2025, 09:00 PM
bdstone914   What no $18/fuse option :rotfl: We can ma...   Aug 31 2025, 06:27 AM
JamesM   Huh? Maybe 10 for 4 bucks? Would put you in th...   Aug 30 2025, 10:24 PM
Superhawk996   Huh? Maybe 10 for 4 bucks? Would put you in t...   Aug 30 2025, 11:22 PM
wonkipop   Huh? Maybe 10 for 4 bucks? Would put you in ...   Aug 31 2025, 01:25 AM
Superhawk996   [quote name='JamesM' post='3221968' date='Aug 31...   Aug 31 2025, 06:36 AM
bdstone914   [quote name='wonkipop' post='3221973' date='Aug 3...   Aug 31 2025, 06:43 AM
Superhawk996   We have sold the Pudenz fuse packs for $3...   Aug 31 2025, 06:51 AM
bdstone914   We have sold the Pudenz fuse packs for ...   Aug 31 2025, 07:26 AM
wonkipop   [quote name='wonkipop' post='3221973' date='Aug 3...   Aug 31 2025, 03:15 PM
Dave_Darling   Hmmmm.... Now I'm starting to wonder if I can...   Aug 31 2025, 05:29 AM
bdstone914   Hmmmm.... Now I'm starting to wonder if I ca...   Aug 31 2025, 06:30 AM
wonkipop   Hmmmm.... Now I'm starting to wonder if I c...   Aug 31 2025, 03:30 PM
bdstone914   I have in an emergency wrapped a burned out fuse i...   Aug 31 2025, 06:34 AM
Spoke   I have in an emergency wrapped a burned out fuse ...   Aug 31 2025, 07:52 AM
bdstone914   I have in an emergency wrapped a burned out fuse...   Aug 31 2025, 10:28 AM
914Wes   I have in an emergency wrapped a burned out fuse...   Aug 31 2025, 12:27 PM
JamesM   [quote name='Spoke' post='3222025' date='Aug 31 2...   Aug 31 2025, 04:12 PM
wonkipop   [quote name='Spoke' post='3222025' date='Aug 31 ...   Aug 31 2025, 04:34 PM
JamesM   look closer at little fuse datasheets. just say...   Aug 31 2025, 10:17 PM
wonkipop   [quote name='wonkipop' post='3222095' date='Aug 3...   Sep 1 2025, 01:17 AM
JamesM   not popping when its supposed to. Then that w...   Sep 1 2025, 10:37 AM
Superhawk996   not popping when its supposed to. Then that ...   Sep 1 2025, 11:21 AM
wonkipop   [quote name='JamesM' post='3222191' date='Sep 1 2...   Sep 2 2025, 02:08 AM
JamesM   Stop making sense. I refuse! :D Gr...   Sep 2 2025, 10:29 PM
wonkipop   [quote name='Superhawk996' post='3222194' date='S...   Sep 3 2025, 01:10 AM
JamesM   hats off to you mate. nothing like an empirica...   Sep 3 2025, 09:27 PM
wonkipop   hats off to you mate. nothing like an empiric...   Sep 3 2025, 10:26 PM
914Wes   [quote name='914Wes' post='3222059' date='Aug 31 ...   Aug 31 2025, 05:34 PM
bdstone914   @JamesM ' date='Aug 31 2025, 03:12 PM...   Aug 31 2025, 07:30 PM
bdstone914   @JamesM ' date='Aug 31 2025, 03:12 PM...   Aug 31 2025, 09:46 PM
fixer34   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Sep 1 2025, 04:04 PM
bdstone914   It is also common for the relay board plastic arou...   Aug 31 2025, 06:40 AM
davep   I think that a baggie of 15 fuses for $30 to ...   Aug 31 2025, 06:44 AM
brant   Early on in 914 worlds existence We used to make ...   Aug 31 2025, 09:15 AM
Superhawk996   Early on in 914 worlds existence We used to make...   Aug 31 2025, 10:47 AM
mepstein   I think there’s a small percentage of the 914 cr...   Aug 31 2025, 11:01 AM
914Wes   I think there’s a small percentage of the 914 c...   Aug 31 2025, 12:12 PM
Superhawk996   With only a few hundred white 8 amp fuses availa...   Aug 31 2025, 12:21 PM
wonkipop   I think there’s a small percentage of the 914 ...   Aug 31 2025, 03:44 PM
fixer34   I think there’s a small percentage of the 914 ...   Sep 1 2025, 04:12 PM
StarBear   [quote name='914Wes' post='3222054' date='Aug 31 ...   Sep 2 2025, 06:01 AM
Lucky9146   Agree, "You’re doing the community a huge f...   Aug 31 2025, 03:47 PM
Superhawk996   I mean it would have been impressive enough had yo...   Sep 2 2025, 10:39 PM
Artfrombama   My thoughts; The aluminum fuse element over time h...   Sep 2 2025, 10:50 PM
Superhawk996   My thoughts; The aluminum fuse element over time ...   Sep 2 2025, 11:01 PM
JamesM   Regardless I’ve seen enough wiring done with w...   Sep 2 2025, 11:45 PM
JamesM   My thoughts; The aluminum fuse element over time ...   Sep 2 2025, 11:32 PM
wonkipop   My thoughts; The aluminum fuse element over time...   Sep 3 2025, 01:17 AM
bdstone914   This is why you don't want thermoplastic fuses...   Sep 4 2025, 08:49 PM
JamesM   This is why you don't want thermoplastic fuse...   Sep 4 2025, 10:42 PM
- Lo-Fi Version Time is now: 5th September 2025 - 05:00 AM
