914Wes |
Newbie ![]() Group: Members Posts: 41 Joined: 9-March 22 From: SO CAL Member No.: 26,388 Region Association: Southern California ![]() |
I found a stash of ceramic fuses in 8, 16, and 25 amp. About 2-300 of each are available. I was wondering what do you guys figure spare fuses are worth now that they are not being made in ceramic anymore. How would you guys like to purchase spares? I could make them into complete set of 12 for the fuse panel, 1 of each needed depending on year, or perhaps just small 5 packs like the 911 did it with 3 x 8 amp fuses, 1x 16 amp, 1 x 25 amp? Obviously not trying to do this to get rich but would need to make it worth my time to repack/ship fuses.
Artfrombama |
Member ![]() ![]() Group: Members Posts: 354 Joined: 21-January 24 From: North Alabama Member No.: 27,870 Region Association: South East States ![]() ![]() |
My thoughts;
The aluminum fuse element over time has a dissimilar metal corrosion (galvanic corrosion) with the metal of the fuse block contacts... Viola, electrical resistance/heat. Even though the circuit isn't overloaded enough to blow the fuse, the cheepie fuse melts. I think we all have seen fuse contacts that have overheated and turned color and lost some spring tension. It's a poor design even with the best fuses. |
Superhawk996 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,363 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch ![]() ![]() |
My thoughts; The aluminum fuse element over time has a dissimilar metal corrosion (galvanic corrosion) with the metal of the fuse block contacts... Viola, electrical resistance/heat. Even though the circuit isn't overloaded enough to blow the fuse, the cheepie fuse melts. Very plausible. But I think goes back to what JamesM was arguing that high resistance was the source of the problem not the plastic per se? I know I’ve seen fuse blocks with plenty of questionable “patina”. Regardless I’ve seen enough wiring done with wire nuts, electrical tape, and just twisting wires together that I’m just surprised that we still have a decent population of 914’s that has defied the abuse and the odds and continue to survive. And for the record - put me down for some ceramic bits as a kit . . . But I’m out at $18/fuse (IMG:style_emoticons/default/lol-2.gif) |
Lo-Fi Version | Time is now: 5th September 2025 - 05:00 AM |
