 Forum Rules Classified Rules!
> FS: 75 914 1.8 Copper Metallic w/ rebuilt engine and L-Jet FI, Former TX car UPDATE: Wife passed away, sale on hold
914rrr
post Sep 4 2025, 06:45 AM
Reluctant Sale!
Former TX 914 with minimal rust. Previous family owned the car over 40+ years.
Pros:
Rare (one year only) L99K Copper Metallic exterior!
Near Flawless OG factory dash!
Engine recently rebuilt by Vintage Porsche VW expert Tony Proasi using new AA cylinder heads and AA Big Bore Kit
Factory Appearance Group w/ Fog Lights / Center Console and Gauges
PORSCHE Rear Center Reflector
PORSCHE Aftermarket Embossed Rocker Panels
Riviera Alloy Wheels
New Fuel Tank and Fuel Line Screen
Factory Bosch 1.8 L Jet Fuel Injection with new dual FI relay, fuel filter, vacuum hoses and fuel hoses
Bursch Performance Exhaust System
New Battery
New Accelerator Pedal and Pedal Pads
New Fully Retracting Antenna with Key
Replaced Oil Filler Funnel and installed new Oil Filler Cap O Ring and Oil Filler Housing base gasket
Starts right up, runs and idles great! Driven as-is to several Car Shows and C&C's.
Also included: Excellent used factory battery tray with stand (has all factory mounts for ECU, etc.), factory correct 75 1.8 charcoal canister and bracket with new hoses, and front metal cover for under tank / steering rack area.
Cons:
Older repaint in the original L99K color is a “10 footer” with several dings, dents, scratches, peeling clear coat, etc.
Brakes work but likely need attention.
Needs clutch cable adjusted or possibly replaced.
Small oil leak at oil temp sender (likely an easy fix with new / additional gasket). Design flaw / very common 914 issue.
Wipers, fresh air blower and horn not working. (may be easy fixes ex: tach was inop and simply needed wire switched to the other coil terminal).
Needs J tubes and topside heater blower hoses. NOTE: Heater blower does work and heater flapper boxes present. May need 1 or more heater cables replaced.
90% tread on tires with minimal dry rot, but tires are extremely old and possibly out of round
Rust present on rear 1" of battery tray (have repair sheet metal, see above), small amount in hell hole area and on underside near passenger side rear “donut”, drivers side qtr. panel adjacent to roof sail panel, bubbling on back trunk edge and perforation near center back edge of rear trunk floor. Have pics of all these areas.
Running, driving 914 that would be great solid “driver” with a few fixes or an Excellent full restoration candidate!
Please PM with your email address I’ll provide additional information and / or additional pics.
Price: Sale on Hold for now
NOTE: Car is currently in Louisville, KY
Mileage: 50710 TMU
914rrr
post Sep 4 2025, 06:50 AM
914rrr   FS: 75 914 1.8 Copper Metallic w/ rebuilt engine and L-Jet FI   Sep 4 2025, 06:45 AM
914rrr   RE: FS: 75 914 1.8 Copper Metallic w/ rebuilt engine and L-Jet FI   Sep 4 2025, 06:48 AM
914rrr   RE: FS: 75 914 1.8 Copper Metallic w/ rebuilt engine and L-Jet FI   Sep 4 2025, 06:50 AM
914rrr   RE: FS: 75 914 1.8 Copper Metallic w/ rebuilt engine and L-Jet FI   Sep 4 2025, 07:03 AM
914rrr   The 914 is tagged and titled in TN. It starts ri...   Sep 4 2025, 07:08 AM
914rrr   Floor pans are in great shape with the except...   Sep 4 2025, 07:14 AM
914rrr   RE: FS: 75 914 1.8 Copper Metallic w/ rebuilt engine and L-Jet FI   Sep 4 2025, 07:18 AM
914rrr   RE: FS: 75 914 1.8 Copper Metallic w/ rebuilt engine and L-Jet FI   Sep 4 2025, 07:21 AM
914rrr   RE: FS: 75 914 1.8 Copper Metallic w/ rebuilt engine and L-Jet FI   Sep 4 2025, 07:24 AM
914rrr   Front bulkhead carpeting and fuel pump cover...   Sep 4 2025, 03:24 PM
914rrr   Floor pans inside are clean and all the floor ...   Sep 4 2025, 03:32 PM
914rrr   RE: FS: 75 914 1.8 Copper Metallic w/ rebuilt engine and L-Jet FI   Sep 7 2025, 06:09 PM
914rrr   RE: FS: 75 914 1.8 Copper Metallic w/ rebuilt engine and L-Jet FI   Sep 15 2025, 09:51 AM
914rrr   RE: FS: 75 914 1.8 Copper Metallic w/ rebuilt engine and L-Jet FI   Oct 18 2025, 07:29 AM
914rrr   RE: FS: 75 914 1.8 Copper Metallic w/ rebuilt engine and L-Jet FI   Nov 6 2025, 11:57 AM
914rrr   Doors are super clean as well.   Nov 17 2025, 05:38 PM
914rrr   Cowl and windshield area are awesome as well.   Nov 18 2025, 12:44 PM
RacingDreamz   PM sent.   Nov 19 2025, 07:21 PM
914rrr   Sale on hold for now due to wife's passing. I...   Dec 9 2025, 07:14 AM
- Lo-Fi Version Time is now: 24th June 2026 - 11:03 PM
