| chmillman |
Sep 7 2025, 10:03 AM
Member ![]() ![]() Group: Members Posts: 320 Joined: 15-June 24 From: Switzerland Member No.: 28,183 Region Association: Europe
Right now the MPS in my car is mounted with some sheet metal screws and old squished rubber grommets. Not at all the original mountings... Didn't see any suppliers for OE-style replacements anywhere near here, so I am looking at re-mounting it on some rubber standoffs like this:
10mm in diameter, 10mm high, M4 threaded studs (Form "SS"). Three different Shore A hardnesses available, 40, 55 and 70. The same ones without the "necking down" in the middle are also possible: The idea is to mount the standoffs to the body sheet metal and then be able to easily bolt/unbolt the MPS on the protruding studs with M4 locknuts and flat washers. What do you think? The mounting should be soft enough to damp out vibration but not so soft to allow the thing to shake significantly. |
| JeffBowlsby |
Sep 9 2025, 08:10 AM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,165 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
Nice Mitch!
The groove diameter of the original is 11mm, it may compress enough to squeeze into the bracket. |
chmillman MPS mounting rubber feet Sep 7 2025, 10:03 AM
Ishley McMaster Carr has rubber grommets that will work w... Sep 7 2025, 11:00 AM
914Sixer NEW ones are NOT available. Might be able to use ... Sep 7 2025, 11:31 AM
JamesM Only real downside I have seen with using the stan... Sep 7 2025, 02:16 PM
chmillman
Only real downside I have seen with using the sta... Sep 7 2025, 02:22 PM
JeffBowlsby I wonder if these would work?
https://www.maxware... Sep 7 2025, 03:26 PM
chmillman
https://www.maxwar... Sep 8 2025, 03:15 AM
FlacaProductions I'm looking for something on this as well. I ... Sep 8 2025, 07:42 AM
chmillman
I'm looking for something on this as well. I... Sep 8 2025, 11:12 AM
JeffBowlsby The original rubber grommet:
OD 16mm
ID 9mm
6mm T... Sep 8 2025, 05:04 PM
chmillman
OD 16mm
ID 9mm
6mm ... Sep 9 2025, 01:19 AM
914Sixer Went to ACE hardware and went through all the bron... Sep 17 2025, 04:04 PM
JamesM
Went to ACE hardware and went through all the bro... Sep 19 2025, 12:38 AM
JeffBowlsby
Which McMaster Carr PNs of these works for the i... Sep 19 2025, 10:30 AM
FlacaProductions I was also working from home and got this back fro... Sep 19 2025, 08:27 AM
JeffBowlsby
I was also working from home and got this back fr... Sep 19 2025, 10:38 AM
FlacaProductions Correct on 3 needed - but I like spares.
$5.... Sep 19 2025, 11:56 AM
chmillman Did a Google search for the grommet part number…... Sep 19 2025, 02:22 PM
FlacaProductions Yup - not real hard to find but everyone's shi... Sep 19 2025, 04:20 PM
chmillman
Yup - not real hard to find but everyone's sh... Sep 20 2025, 12:05 AM
JeffBowlsby The flange on the metal sleeve is the bearing surf... Sep 19 2025, 05:33 PM
JeffBowlsby double post. Sep 19 2025, 05:34 PM![]() ![]() |
Lo-Fi Version | Time is now: 27th January 2026 - 09:00 AM |
