| Artfrombama |
Sep 10 2025, 10:53 PM
Artfrombama ![]() ![]() Group: Members Posts: 453 Joined: 21-January 24 From: One of the chosen few Member No.: 27,870 Region Association: South East States
Adjusted the valves using the TDC method with satisfactory results but I find it somewhat difficult and takes too long.
The way I’ve always adjusted valves is with a remote starter button and bumping the starter. When the exhaust open, adjust the intake. Then when the intake fully open and starting to close, adjust the exhaust. EOIC Is either correct? (IMG:style_emoticons/default/WTF.gif) If not please explain. |
| Superhawk996 |
Sep 11 2025, 08:07 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,832 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
Nothing wrong with the Capt’n method but it needs to be acknowledged that its application is limited to the cam lobe sharing of the VW horizontally opposed engines.
The tried and true TDC of the compression stroke method, following the engine firing order is universally applicable. |
Artfrombama Adjusting Valves Sep 10 2025, 10:53 PM
emerygt350 I like the crusty method. Put it in fifth, roll t... Sep 11 2025, 05:16 AM
Kansas 914
I like the crusty method. Put it in fifth, roll ... Sep 11 2025, 05:24 AM
VaccaRabite
The way I’ve always adjusted valves is with a r... Sep 11 2025, 05:44 AM
GregAmy Cap'n method, both valve covers off, remote st... Sep 11 2025, 07:42 AM
emerygt350 I don't even bother with the 'fast way... Sep 11 2025, 08:26 AM
930cabman just had a look at the wise words of the Cap, look... Sep 11 2025, 10:08 AM
ctc911ctc I spent a good deal of time analyzing Krusty's... Sep 11 2025, 01:25 PM
Literati914 The simplest way that I've found and IMHO, for... Sep 12 2025, 08:12 AM
Artfrombama Thanks to everyone that responded.
I'm wishi... Sep 12 2025, 12:09 PM
Dave_Darling
I think I will continue to use the EOIC method, m... Sep 13 2025, 09:57 PM
rfinegan I'm of the school like emerygt350, we know the... Sep 13 2025, 07:11 AM
neyen14 With one wheel off the ground and the car in 5th, ... May 6 2026, 09:53 AM
VaccaRabite
With one wheel off the ground and the car in 5th,... May 6 2026, 11:03 AM
neyen14
With one wheel off the ground and the car in 5th... May 6 2026, 11:36 AM
FlacaProductions Is the e-brake on? May 6 2026, 10:16 AM
neyen14
Is the e-brake on?
Sadly.... no May 6 2026, 10:22 AM
friethmiller
Is the e-brake on?
Sadly.... no
If the car is ... May 6 2026, 11:04 AM
Dave_Darling "Slight gear"? "Total gear"? ... May 6 2026, 01:43 PM![]() ![]() |
Lo-Fi Version | Time is now: 6th May 2026 - 03:54 PM |
