jmargush |
Member ![]() ![]() Group: Members Posts: 487 Joined: 8-June 04 From: Goshen, IN Member No.: 2,176 ![]() |
Now that I have an oil pressure gauge in car I can see drastic swings in oil pressure while on the autox course.
So this prompts a few questions. Does the Type IV have an oil system that really isn't adequate for higher G loads and quick direction changes? Will I see an noticeable difference if i go tuna can sump vs. Deep sump vs. Accu sump? I understand the Accu sump is likely the way to go but there is also a significant entry cost difference and more involvement on the install. I hate to spend the money on the easy install of a tuna can if it isn't going to make a noticeable difference and I should have just put the money toward the Accu sump. |
Geezer914 |
Geezer914 ![]() ![]() ![]() ![]() Group: Members Posts: 2,066 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States ![]() ![]() |
I had a deep sump installed and it took forever for the oil to get to operating temperature and it hung about 1 1/2" below the engine bar, ground clearance??. I installed a tuna can and have not seen any loss in oil pressure when hard corning. No experience with accusump.
jmargush |
I had a deep sump installed and it took forever for the oil to get to operating temperature and it hung about 1 1/2" below the engine bar, ground clearance??. I installed a tuna can and have not seen any loss in oil pressure when hard corning. No experience with accusump. Do you do any autoxing? |
Geezer914 |
I had a deep sump installed and it took forever for the oil to get to operating temperature and it hung about 1 1/2" below the engine bar, ground clearance??. I installed a tuna can and have not seen any loss in oil pressure when hard corning. No experience with accusump. Do you do any autoxing? I have done autocross with the tuna can, no loss in pressure. |
Lo-Fi Version | Time is now: 12th September 2025 - 07:29 PM |
