Chad911sc |
Member ![]() ![]() Group: Members Posts: 178 Joined: 24-September 24 From: Florida Member No.: 28,374 Region Association: South East States ![]() |
So I finally finished every aspect of my restoration and I’m on the final step before really being able to break my new 2056 in. I have the idle circuit close enough to where it needs to be with idle jets of 50. My problem is my transition from idle circuit to the main circuit. I had purchased a set of Gene Berg venturis that were a 30 idle circuit and then with wide open throttle they would increase the flow to 34. I thought this would be good with better flow at the top due to the web cam (86a) which is supposed to be more mid and top range power. I have ported 2.0 heads and 96mm pistons and cylinders. It also has the 123 distributor set on setting #3. The timing is set at 5 degrees base timing and 28 degrees total.
The problem is that if I even try to open the throttle more than an inch or so, the AFR gauge slams over to 16 or higher. So I’ve only driven it a few times after adjustments, and it does the same thing everytime. I took out the fancy dual plain Venturis and put in a set of stock functioning 30 vents and just took it for another spin. It does the same thing with the 30s. Current set up: ET F11 Idle 50 Mains 130 AC 180 Vents 30 My float level is set at 10.5 with the gasket. I’m at sea level in Florida. As long as I just ride the pedal gently, the AFR stays in the 12-14 range all the way up to 4000 rpm. It idles at 10.5-11.5. The carbs have been rebuilt and are synced and balanced. I am ordering a set of AC and mains so I can adjust further as needed. Should I try to go down on the air correction jet first to fatten it up on the top? Or maybe something different with the float height to provide more fuel in the bowl? Thanks in advance for all your advice. Can’t wait to be able to run this thing!! Attached thumbnail(s) ![]() |
Chad911sc |
So after reading the material you sent me, I thought it would be a good idea to check where all my screw settings were adjusted. I read the CB performance low circuit running and it took me step by step through the tuning process again. The steps that I followed the first time were very similar, but not exact. After following their method, the engine sounds like an angry bee when I rev it. Wow what a difference. The AFR at idle is now 12.5 fairly steady and hums at 850-900 idle speed. Starts very easily now as well.
I will take if for a spin tomorrow and report back any issues. |
930cabman |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,256 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States ![]() ![]() |
So after reading the material you sent me, I thought it would be a good idea to check where all my screw settings were adjusted. I read the CB performance low circuit running and it took me step by step through the tuning process again. The steps that I followed the first time were very similar, but not exact. After following their method, the engine sounds like an angry bee when I rev it. Wow what a difference. The AFR at idle is now 12.5 fairly steady and hums at 850-900 idle speed. Starts very easily now as well. I will take if for a spin tomorrow and report back any issues. Webers can be tricky, but when dialed in they sing glad you got them happy |
Lo-Fi Version | Time is now: 12th September 2025 - 07:30 PM |
