VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,784 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() ![]() |
When I’m on the freeway I get a vibration through the steering wheel if I’m going over 70.
On surface roads everything is smooth sailing. It’s probably a wheel that threw off its weight, but I can’t check that till Monday. Bearing are new. Rotors are new. What’s the checklist? |
rjames |
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 4,366 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest ![]() ![]() |
A lost wheel weight is a solid culprit.
How old are the tires? Maybe tread separation? Do you have a spare you could use to swap your wheels out one at time to rule them out? Grab the wheels and check for play to ensure it's not a loose or bad bearing (or worn spindle), too. |
Lo-Fi Version | Time is now: 13th September 2025 - 08:33 PM |
