> Webber IDF 40s, Help with tuning
Chad911sc
post Sep 11 2025, 09:18 AM
So I finally finished every aspect of my restoration and I’m on the final step before really being able to break my new 2056 in. I have the idle circuit close enough to where it needs to be with idle jets of 50. My problem is my transition from idle circuit to the main circuit. I had purchased a set of Gene Berg venturis that were a 30 idle circuit and then with wide open throttle they would increase the flow to 34. I thought this would be good with better flow at the top due to the web cam (86a) which is supposed to be more mid and top range power. I have ported 2.0 heads and 96mm pistons and cylinders. It also has the 123 distributor set on setting #3. The timing is set at 5 degrees base timing and 28 degrees total.
The problem is that if I even try to open the throttle more than an inch or so, the AFR gauge slams over to 16 or higher. So I’ve only driven it a few times after adjustments, and it does the same thing everytime.
I took out the fancy dual plain Venturis and put in a set of stock functioning 30 vents and just took it for another spin. It does the same thing with the 30s.
Current set up:
ET F11
Idle 50
Mains 130
AC 180
Vents 30
My float level is set at 10.5 with the gasket.
I’m at sea level in Florida.
As long as I just ride the pedal gently, the AFR stays in the 12-14 range all the way up to 4000 rpm. It idles at 10.5-11.5.
The carbs have been rebuilt and are synced and balanced.
I am ordering a set of AC and mains so I can adjust further as needed.
Should I try to go down on the air correction jet first to fatten it up on the top?
Or maybe something different with the float height to provide more fuel in the bowl?
Thanks in advance for all your advice. Can’t wait to be able to run this thing!!
Chad911sc
post Sep 13 2025, 03:43 PM
@SUPERHAWK996
Once again you are spot on! (IMG:style_emoticons/default/first.gif)
Put the 28s back in and took her for a spin….and whalaaa! Full pedal available and pulling nicely.
It actually is a little fat at WOT. I have a set of 120 mains I am going to try and see if it pulls better at the top with them. At WOT my AFR is reading 10-11.7
I also rechecked my float levels and they were not at what I had previously set them at, they must have changed when I pulled them apart the first time. So I reset both at 10.5 with gasket.
Also my fuel pressure had creeped up to 3.5, so I placed it just below 3.0lbs
Will change out the mains and see what happens tomorrow.
Thanks again to all of you who took the time to post and help me with every step of my restoration over the last 1.5 years. It’s been a daily grind, but always makes me happy to build something, and then have the satisfaction of ripping it down the road with a huge (IMG:style_emoticons/default/stromberg.gif) eating grin. (IMG:style_emoticons/default/aktion035.gif)
porschetub
post Sep 13 2025, 10:35 PM
QUOTE(Chad911sc @ Sep 14 2025, 09:43 AM) *
@SUPERHAWK996
what a great result ,take your mains down to 125 ,it seems a common number with these carbs running 28mm vents ...just saying .
Cheers.
Chad911sc   Webber IDF 40s   Sep 11 2025, 09:18 AM
densible1   I'm also at sea level with my 2270 (2256) buil...   Sep 11 2025, 12:01 PM
densible1   Wait, correction I meant 5-7 static advance on the...   Sep 11 2025, 12:04 PM
Chad911sc   After re-reading my post I forgot to add that the ...   Sep 11 2025, 01:13 PM
Superhawk996   How about some homework? Suggest you read this t...   Sep 11 2025, 01:52 PM
Chad911sc   I still have a set of 28 vents, so that is an opti...   Sep 11 2025, 02:16 PM
Chad911sc   So after reading the material you sent me, I thoug...   Sep 11 2025, 05:22 PM
930cabman   So after reading the material you sent me, I thou...   Sep 12 2025, 04:59 AM
Superhawk996   :trophy: :popcorn:   Sep 11 2025, 08:07 PM
Chad911sc   After the test drive today, it is tuned better tha...   Sep 12 2025, 10:55 AM
Superhawk996   I’d normally say increase the idle jet since you...   Sep 12 2025, 02:20 PM
Chad911sc   Perfect… Excellent idea. I will change those out...   Sep 12 2025, 03:44 PM
Superhawk996   There is so much information out there that cont...   Sep 12 2025, 06:52 PM
porschetub   Perfect… Excellent idea. I will change those ou...   Sep 12 2025, 07:53 PM
930cabman   my experience has been, I get them close (no AFR g...   Sep 12 2025, 06:28 PM
Superhawk996   I think it’s probably also worth posting this fr...   Sep 12 2025, 07:16 PM
Superhawk996   And one last item food for thought. The Zenith ...   Sep 12 2025, 07:22 PM
cgnj   I am a Dellorto fan boy. Bought my first set in th...   Sep 12 2025, 07:27 PM
brant   I run big venturis on the race car for 8000 redlin...   Sep 12 2025, 08:24 PM
Chad911sc   @SUPERHAWK996 Once again you are spot on! :fi...   Sep 13 2025, 03:43 PM
porschetub   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Sep 13 2025, 10:35 PM
- Lo-Fi Version Time is now: 14th September 2025 - 04:24 AM
