trojanhorsepower |
Senior Member ![]() ![]() ![]() Group: Members Posts: 941 Joined: 21-September 03 From: Marion, NC Member No.: 1,179 Region Association: None ![]() |
None of the horns I have worked. I looked online but couldn't find anything about how they work (no doubt due to my own poor Googling) so I decided to figure it out myself.
In principal the horn works by by using an electromagnet to pull in a diaphragm. When the diaphragm is deformed the steel plates on the back open the points. Once the points are open the diaphragm relaxes, the points reconnect and the magnet turns on again. Here is the process I went through to restore mine. |
trojanhorsepower |
The horn is often riveted together, with aluminum rivets.
![]() These rivets are easily chiseled off or drilled out. Personally I think a small hammer and cold chisel worked best. I gently hold the horn in the vice and carefully chisel off the rivet head that is against the vice jaw. Then turn the horn to the next rivet. The back of the horn ![]() |
Lo-Fi Version | Time is now: 15th September 2025 - 01:44 AM |
