DennisV |
Senior Member ![]() ![]() ![]() Group: Members Posts: 724 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California ![]() ![]() |
Is there anything that I should give attention while the fuel tank is out?
I have already:
Does the box in top center of photo, which I believe is the Fresh air inlet box, need anything and does the fuel tank need to be out to do it? ![]() Our car is a 1970 914-6. My understanding is charcoal canister didn't appear until later. Tips on installing the fuel hose to lines so I don't end up with a leak? Thank you. |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,259 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
Yup, replace the felt pads that the tank rests on. Clean up where they go, repaint if necessary. Check the gas tank where it sits on the pads; they hold moisture pretty well and can promote rust pinholes in the tank in those spots.
--DD |
DennisV |
There is a drain at the bottom of the gas hole. Make sure it is clear. There should also be a couple of pads/carpet type pieces that are glued in place. The help noises and metal to metal rubbing if the tank moves a little. Thanks for pointing this out. I assume you're referring to the ones seen in this Auto Atlanta video? So there were three black strips? I don't see them in the parts catalog. Were they on all years -4 and -6? ![]() I do have two white strips of felt-like material, but as I recall they went between the metal straps and the tank. ![]() |
Lo-Fi Version | Time is now: 18th September 2025 - 11:54 PM |
