> MPS mounting rubber feet, Need to replace mine
chmillman
post Sep 7 2025, 10:03 AM
Region Association: Europe
Right now the MPS in my car is mounted with some sheet metal screws and old squished rubber grommets. Not at all the original mountings... Didn't see any suppliers for OE-style replacements anywhere near here, so I am looking at re-mounting it on some rubber standoffs like this:
10mm in diameter, 10mm high, M4 threaded studs (Form "SS"). Three different Shore A hardnesses available, 40, 55 and 70. The same ones without the "necking down" in the middle are also possible:
The idea is to mount the standoffs to the body sheet metal and then be able to easily bolt/unbolt the MPS on the protruding studs with M4 locknuts and flat washers. What do you think? The mounting should be soft enough to damp out vibration but not so soft to allow the thing to shake significantly.
FlacaProductions
post Sep 19 2025, 08:27 AM
I was also working from home and got this back from my local Porsche dealer concerning the grommets:
I am following up on a request for x4 of P/N: 113-957-855. Total cost before taxes for these parts will be $57.48.
That's a NO.
JeffBowlsby
post Sep 19 2025, 10:38 AM
QUOTE(FlacaProductions @ Sep 19 2025, 07:27 AM) *
That's a NO.
Only 3 rubber sleeves are needed per MPS.
$5.88 each from Sunset Porsche https://www.sunsetporscheparts.com/search?s...str=113-957-855
Its a reasonable cost for the real deal part.
The PN for the metal sleeve is 311-906-057, which is NLA so find it used or improvise a substitute.
chmillman   MPS mounting rubber feet   Sep 7 2025, 10:03 AM
Ishley   McMaster Carr has rubber grommets that will work w...   Sep 7 2025, 11:00 AM
914Sixer   NEW ones are NOT available. Might be able to use ...   Sep 7 2025, 11:31 AM
JamesM   Only real downside I have seen with using the stan...   Sep 7 2025, 02:16 PM
chmillman   Only real downside I have seen with using the sta...   Sep 7 2025, 02:22 PM
JeffBowlsby   I wonder if these would work? https://www.maxware...   Sep 7 2025, 03:26 PM
chmillman   I wonder if these would work? https://www.maxwar...   Sep 8 2025, 03:15 AM
FlacaProductions   I'm looking for something on this as well. I ...   Sep 8 2025, 07:42 AM
chmillman   I'm looking for something on this as well. I...   Sep 8 2025, 11:12 AM
JeffBowlsby   The original rubber grommet: OD 16mm ID 9mm 6mm T...   Sep 8 2025, 05:04 PM
chmillman   The original rubber grommet: OD 16mm ID 9mm 6mm ...   Sep 9 2025, 01:19 AM
JeffBowlsby   Nice Mitch! The groove diameter of the origin...   Sep 9 2025, 08:10 AM
914Sixer   Went to ACE hardware and went through all the bron...   Sep 17 2025, 04:04 PM
JamesM   Went to ACE hardware and went through all the bro...   Sep 19 2025, 12:38 AM
JeffBowlsby   Which McMaster Carr PNs of these works for the i...   Sep 19 2025, 10:30 AM
FlacaProductions   I was also working from home and got this back fro...   Sep 19 2025, 08:27 AM
JeffBowlsby   I was also working from home and got this back fr...   Sep 19 2025, 10:38 AM
FlacaProductions   Correct on 3 needed - but I like spares. $5....   Sep 19 2025, 11:56 AM
chmillman   Did a Google search for the grommet part number…...   Sep 19 2025, 02:22 PM
FlacaProductions   Yup - not real hard to find but everyone's shi...   Sep 19 2025, 04:20 PM
chmillman   Yup - not real hard to find but everyone's sh...   Sep 20 2025, 12:05 AM
JeffBowlsby   The flange on the metal sleeve is the bearing surf...   Sep 19 2025, 05:33 PM
JeffBowlsby   double post.   Sep 19 2025, 05:34 PM
3 User(s) are reading this topic (2 Guests and 0 Anonymous Users)
1 Members: Lockwodo
- Lo-Fi Version Time is now: 27th January 2026 - 08:57 AM
