> L jet on 2L heads, how to fit
rfinegan
post Sep 20 2025, 09:55 AM
How are people fitting the Ljet intake manifolds to work with 2.0L heads? FWIW this will be on my 2056.
Dave_Darling
post Sep 20 2025, 03:09 PM
914 Idiot
You'd have to use the 2-liter runners. They're shorter than the 1.8 ones, so you need longer hoses to connect to the intake air distributor. (AKA the "plenum".) The runner pipes are the same diameter, or close enough.
--DD
rfinegan   L jet on 2L heads   Sep 20 2025, 09:55 AM
914werke   I used custom silicone connector hoses   Sep 20 2025, 10:41 AM
rfinegan   So you use the Djet runners on a Ljet plenum? SO i...   Sep 20 2025, 10:51 AM
Dave_Darling   You'd have to use the 2-liter runners. They...   Sep 20 2025, 03:09 PM
914Sixer   Take the 1.8 runners and drill 3rd center hole. Y...   Sep 20 2025, 03:32 PM
JamesM   Take the 1.8 runners and drill 3rd center hole. ...   Sep 20 2025, 07:14 PM
bdstone914   @[url=http://www.914world.com/bbs2/index.php?showu...   Sep 25 2025, 06:53 AM
TRP   Will you be running bigger injectors for the 2056?...   Sep 20 2025, 06:45 PM
JamesM   Find a 912e system :lol4: :lol4: :lol4: Serio...   Sep 20 2025, 07:13 PM
914werke   So you use the (2.0L) D-jet runners on a Ljet ple...   Sep 20 2025, 10:30 PM
GregAmy   Genuine curiosity: why? Rebuiliding a 1.8L with 2L...   Sep 21 2025, 06:26 AM
rfinegan   @GregAmy , This will be and after market EFI crank...   Sep 21 2025, 09:06 AM
rfinegan   Thanks every one for the intake tips....no more sy...   Sep 21 2025, 09:09 AM
914werke   In my case it was a 2056 that I fitted a GoWesty T...   Sep 21 2025, 11:46 AM
GregAmy   Good info...so it appears the LJet is the preferre...   Sep 21 2025, 03:30 PM
ClayPerrine   I have run L-Jet on a 2.0 engine. The runners are...   Sep 22 2025, 05:41 AM
JamesJ   I have run L-Jet on a 2.0 engine. The runners ar...   Nov 21 2025, 12:57 PM
rfinegan   Chat GTP 5 on throttle body size for 2056: Short v...   Sep 24 2025, 09:34 AM
Geezer914   I am running a 2056 with Ljet FI. Installed a 50m...   Sep 24 2025, 09:51 AM
JamesJ   I am running a 2056 with Ljet FI. Installed a 50...   Nov 22 2025, 07:22 AM
Geezer914   [quote name='Geezer914' post='3225523' date='Sep ...   Nov 23 2025, 09:39 AM
JamesJ   I am running a 2056 with Ljet FI. Installed a 50...   Nov 24 2025, 11:41 PM
rbzymek   I am running a 2056 with Ljet FI. Installed a 50...   Dec 5 2025, 08:58 AM
rfinegan   Thanks all for the insights and advice as i move i...   Sep 24 2025, 08:41 PM
914Sixer   Yep, that was all read pointed out, my bad.   Sep 25 2025, 06:57 AM
914werke   Here you go :) https://members.rennlist.com/demi...   Nov 22 2025, 02:44 PM
JamesJ   Thanks guys! Super helpful! Rob, we'l...   Nov 24 2025, 08:45 PM
rfinegan   PROGRESS: While I had the welder out for the O2 b...   Dec 30 2025, 01:38 PM
Geezer914   When I installed the modified 50mm Vanagon throttl...   Dec 31 2025, 09:37 AM
rfinegan   Geezer914, I plan on giving ^this^ a try once its ...   Dec 31 2025, 09:54 AM
- Lo-Fi Version Time is now: 12th March 2026 - 02:07 AM
