| GulfRacer |
Sep 20 2025, 01:48 PM
Newbie ![]() Group: Members Posts: 8 Joined: 19-April 25 From: NJ Member No.: 28,724 Region Association: North East States |
I'm hoping some collective wisdom can help me through a frustrating problem. I have 1974 Bumblebee that I've owned for about 6 months. The 2.0 was rebuilt to a 2056 shortly before I purchased it. It has a Raby 9590 camshaft, original D-Jet and 123 distributor. When I first got the car, it was running great. It has since developed an intermittent stutter/bucking. It occurs most commonly around 3000 RPM when cruising, but once it happens, it continues when applying throttle. It doesn't usually occur until the engine has warmed up - the first several minutes of the drive are usually good.
I replaced the throttle sensor board which did not solve the problem. I disconnected the throttle sensor, and the problem is still present. I replaced the fuel injection harnesss which did not help. The fuel injectors are all new with the engine rebuild, but cylinder 3 injector stopped firing a few months ago, and I replaced it with a new one. I'm at a loss as to where to go next. Any advice would be greatly appreciated. Jason |
| Lockwodo |
Sep 20 2025, 06:55 PM
Member ![]() ![]() Group: Members Posts: 238 Joined: 23-December 21 From: Santa Cruz, Californnia Member No.: 26,193 Region Association: Northern California
Would a faulty MPS cause the lean condition and missing?
| emerygt350 |
Sep 21 2025, 07:47 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,364 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
GulfRacer Engine Stuttering Sep 20 2025, 01:48 PM
Dave_Darling Wiggle all of the wiring in the engine bay while t... Sep 20 2025, 03:07 PM
emerygt350 Interesting. That is a spot where a lean miss is ... Sep 20 2025, 04:06 PM
Olympic 914 I was having a similar problem
On mine it was an ... Sep 20 2025, 05:21 PM
emerygt350
Would a faulty MPS cause the lean condition and ... Sep 21 2025, 07:48 AM
GulfRacer
[quote name='emerygt350' post='3225097' date='Sep... Sep 21 2025, 11:37 AM
cgnj I'm thinking ignition coil. Sits on the tin ab... Sep 23 2025, 12:15 AM
Lockwodo Or perhaps a dodgy ground connection? Sep 23 2025, 09:59 AM
JP101 Thanks for additional suggestions. Coil may make s... Sep 23 2025, 08:22 PM
GulfRacer I still haven't sorted this problem out, and s... Nov 1 2025, 12:08 PM
Ishley Do you have a Bluetooth 123+? If you do you can c... Nov 1 2025, 03:18 PM
emerygt350 I would try replacing the coil and verify it is wi... Nov 2 2025, 06:52 AM
GulfRacer I have some additional information. Thank you for... Nov 2 2025, 10:58 AM
Lockwodo It does seem like the trigger point pulse from the... Nov 2 2025, 11:20 AM
GulfRacer
It does seem like the trigger point pulse from th... Nov 2 2025, 11:23 AM
emerygt350 I wonder if this could be one of those rare times ... Nov 2 2025, 11:32 AM
GulfRacer
I wonder if this could be one of those rare times... Nov 2 2025, 11:37 AM
emerygt350
I wonder if this could be one of those rare time... Nov 2 2025, 07:42 PM
Ishley I’m wondering if you should check the spray patt... Nov 2 2025, 02:45 PM
GulfRacer
I’m wondering if you should check the spray pat... Nov 2 2025, 04:24 PM![]() ![]() |
Lo-Fi Version | Time is now: 3rd November 2025 - 08:19 AM |
