| rfinegan |
Sep 20 2025, 09:55 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,189 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region
How are people fitting the Ljet intake manifolds to work with 2.0L heads? FWIW this will be on my 2056.
| rfinegan |
Sep 21 2025, 09:06 AM
@GregAmy , This will be and after market EFI crank trigger system purchased here.(Eltromotive/clewett) Im think the 1.8 manifold holes can be tig welded up and a center hole added to the flange. Making for a Clean OEM looking system with little fabe work. After its up and running a larger Throttle body can be added with a bolt on Go Westy? We will see how this goes. I am mostly done with the heads as we work on getting the 2056 sealed up again
While I have the welder out , i may as well add an O2 bung to the Bursch/SS HE exhaust too |
rfinegan L jet on 2L heads Sep 20 2025, 09:55 AM
914werke I used custom silicone connector hoses Sep 20 2025, 10:41 AM
rfinegan So you use the Djet runners on a Ljet plenum? SO i... Sep 20 2025, 10:51 AM
Dave_Darling You'd have to use the 2-liter runners. They... Sep 20 2025, 03:09 PM
914Sixer Take the 1.8 runners and drill 3rd center hole. Y... Sep 20 2025, 03:32 PM
JamesM
Take the 1.8 runners and drill 3rd center hole. ... Sep 20 2025, 07:14 PM
bdstone914 @[url=http://www.914world.com/bbs2/index.php?showu... Sep 25 2025, 06:53 AM
TRP Will you be running bigger injectors for the 2056?... Sep 20 2025, 06:45 PM
JamesM Find a 912e system :lol4: :lol4: :lol4:
Serio... Sep 20 2025, 07:13 PM
914werke So you use the (2.0L) D-jet runners on a Ljet ple... Sep 20 2025, 10:30 PM
GregAmy Genuine curiosity: why? Rebuiliding a 1.8L with 2L... Sep 21 2025, 06:26 AM
rfinegan Thanks every one for the intake tips....no more sy... Sep 21 2025, 09:09 AM
914werke In my case it was a 2056 that I fitted a GoWesty T... Sep 21 2025, 11:46 AM
GregAmy Good info...so it appears the LJet is the preferre... Sep 21 2025, 03:30 PM
ClayPerrine I have run L-Jet on a 2.0 engine. The runners are... Sep 22 2025, 05:41 AM
JamesJ
I have run L-Jet on a 2.0 engine. The runners ar... Nov 21 2025, 12:57 PM
rfinegan Chat GTP 5
on throttle body size for 2056:
Short v... Sep 24 2025, 09:34 AM
Geezer914 I am running a 2056 with Ljet FI. Installed a 50m... Sep 24 2025, 09:51 AM
JamesJ
I am running a 2056 with Ljet FI. Installed a 50... Nov 22 2025, 07:22 AM
Geezer914
[quote name='Geezer914' post='3225523' date='Sep ... Nov 23 2025, 09:39 AM
JamesJ
I am running a 2056 with Ljet FI. Installed a 50... Nov 24 2025, 11:41 PM
rbzymek
I am running a 2056 with Ljet FI. Installed a 50... Dec 5 2025, 08:58 AM
rfinegan Thanks all for the insights and advice as i move i... Sep 24 2025, 08:41 PM
914Sixer Yep, that was all read pointed out, my bad. Sep 25 2025, 06:57 AM
914werke Here you go :)
https://members.rennlist.com/demi... Nov 22 2025, 02:44 PM
JamesJ Thanks guys! Super helpful!
Rob, we'l... Nov 24 2025, 08:45 PM
rfinegan PROGRESS:
While I had the welder out for the O2 b... Dec 30 2025, 01:38 PM
Geezer914 When I installed the modified 50mm Vanagon throttl... Dec 31 2025, 09:37 AM
rfinegan Geezer914,
I plan on giving ^this^ a try once its ... Dec 31 2025, 09:54 AM![]() ![]() |
Lo-Fi Version | Time is now: 12th March 2026 - 03:40 AM |
