Fart/4 |
Newbie ![]() Group: Members Posts: 8 Joined: 13-February 25 From: California Member No.: 28,619 Region Association: Central California ![]() |
Had the car for about 15 years
Never touched the brakes as in original ( to me ) Rotors , pads etc Over the last about 100 miles brake pedal has gotten progressively Softer and now go's down to the floor pretty much Checked the reservoir and it's bone dry Car still stops reasonable we'll , but pedal is very soft and is about 80% travel when brakes bite or engage Should i immediately just take it to my aircooled guy/ mechanic Or refill the fluid and see what happens approach ? (IMG:style_emoticons/default/beer3.gif) Attached image(s) ![]() |
Superhawk996 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,410 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch ![]() ![]() |
Check floor pan inside car at the pedal cluster and/or under the carpet.
You will most likely find your lost fluid there due to bad master cylinder. If that is where your fluid is; should have the vehicle flatbedded to repair rather than risk loss of brakes during the drive. |
930cabman |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,268 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States ![]() ![]() |
Check floor pan inside car at the pedal cluster and/or under the carpet. You will most likely find your lost fluid there due to bad master cylinder. If that is where your fluid is; should have the vehicle flatbedded to repair rather than risk loss of brakes during the drive. +1, you will not find any fluid on the ground, all the leaking fluid will be under the pedal cluster, and yes - flatbed is the safe call |
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,802 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
Check floor pan inside car at the pedal cluster and/or under the carpet. You will most likely find your lost fluid there due to bad master cylinder. If that is where your fluid is; should have the vehicle flatbedded to repair rather than risk loss of brakes during the drive. +1, you will not find any fluid on the ground, all the leaking fluid will be under the pedal cluster, and yes - flatbed is the safe call (IMG:style_emoticons/default/agree.gif) |
Lo-Fi Version | Time is now: 22nd September 2025 - 11:28 PM |
