> Webcam 73 valve clearance, Does the Webcam change the exhaust valve adjustment
timofly
post Sep 22 2025, 03:15 PM
My 2.0 (actually probably about 2.2 with oversized cylinders) car has had a Webcam 73 in it since a complete overhaul in 2010. I have used the usual recommendation of .006 intake and .008 exhaust for 15 years. I recently read something (and I can't recall where) that said that with the Webcam, the exhaust should be at .006. I know the 1.7 and 1.8 engines called for that, and maybe the source was referring to those engines, but I am curious. It's time for another adjustment. I've always assumed that a bit more clearance might mean the engine will be noisier, but it's less likely to be a cause for deep regrets that setting them too tight. Anybody ever heard this suggestion for .006 on the 2.0 cars?
porschetub
post Sep 22 2025, 04:12 PM
QUOTE(timofly @ Sep 23 2025, 09:15 AM) *
My understanding is that .008 was used when VW used sodium filled valve's , the cam used has no bearing on this and is recommended because sodium exhaust valves are a thing of the past .
You will be fine with .006 ,cheers.
- Lo-Fi Version Time is now: 22nd September 2025 - 11:30 PM
