scrz914 |
Member ![]() ![]() Group: Members Posts: 427 Joined: 21-April 04 From: Santa Cruz, CA Member No.: 1,960 Region Association: Central California ![]() |
I bought the float bowl gauge from partsklassik to double check my bench settings on the float and needle valve. I was surprised to see the level rise to the top. I shut the pump off before it overflowed. In reading the instructions I noticed it said to do the check while running the engine. I only ran the pump. Is there any reason to believe the levels would be different between running the engine as opposed to just running the pump? Also, is it possible that the needle valve is just sticking? I’ve heard even new needle valves can be problematic.
I have Weber IDA3C. Here’s the gauge I bought. Not cheap. But it does come with different needle valve shims. ![]() |
scrz914 |
I went ahead and checked the remaining 3 bowls and realized they wouldn’t overflow. That would be a major design flaw. I’ll have to run the engine to get accurate readings. Just gonna get it warm till it stops backfiring.
I did check psi from both sides of the fuel tee connection and it was 3 psi dead on. What I’m really chasing is a temperature disparity between the left bank/right bank from readings at the exhaust ports. So I’m starting with the simplest most probable problems. I’m not really experienced with carbs so learning as I go. |
930cabman |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,268 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States ![]() ![]() |
I went ahead and checked the remaining 3 bowls and realized they wouldn’t overflow. That would be a major design flaw. I’ll have to run the engine to get accurate readings. Just gonna get it warm till it stops backfiring. I did check psi from both sides of the fuel tee connection and it was 3 psi dead on. What I’m really chasing is a temperature disparity between the left bank/right bank from readings at the exhaust ports. So I’m starting with the simplest most probable problems. I’m not really experienced with carbs so learning as I go. Could the temperature difference a clogged jet or be other than fuel? compression, overlap, .. I considered trying this gauge, but used the setup from Pierce, worked perfect |
scrz914 |
Could the temperature difference a clogged jet or be other than fuel? compression, overlap, .. I considered trying this gauge, but used the setup from Pierce, worked perfect When I first saw the temp differences my mind immediately went to cam timing. But I decided to make the assumption (For now) that the professional mechanic that rebuilt the engine more than likely knew what he was doing and that the amateur that tore apart and cleaned the carbs (me) has more work to do. What is the set up from Pierce? |
930cabman |
Could the temperature difference a clogged jet or be other than fuel? compression, overlap, .. I considered trying this gauge, but used the setup from Pierce, worked perfect When I first saw the temp differences my mind immediately went to cam timing. But I decided to make the assumption (For now) that the professional mechanic that rebuilt the engine more than likely knew what he was doing and that the amateur that tore apart and cleaned the carbs (me) has more work to do. What is the set up from Pierce? It states 48 IDA and was unable to find another one. I have a similar or the same. Works perfect. I considered the gauge from PartsKlassik but was unsure how to view it when installed into the car and when removing things could get messy |
Lo-Fi Version | Time is now: 22nd September 2025 - 11:24 PM |
