> Engine tin behind pushrods
neyen14
post Sep 24 2025, 06:57 AM
I am using 96mm cylinders and the "vertical fin" of tin that goes behind behind the pushrods is hitting the cylinder....
What has anyone else that has had this issue done?
Is there another tin option available for 96mm cylinders?
How drastic will trimming it affect cooling?
Thank you
neyen14   Engine tin behind pushrods   Sep 24 2025, 06:57 AM
emerygt350   I am using 96mm cylinders and the "vertical ...   Sep 24 2025, 07:04 AM
mate914   I am using 96mm cylinders and the "vertical ...   Sep 24 2025, 07:35 AM
neyen14   I am using 96mm cylinders and the "vertical...   Sep 24 2025, 10:18 AM
mate914   [quote name='mate914' post='3225502' date='Sep 24...   Sep 24 2025, 06:45 PM
Geezer914   I installed biral cylinders and had to trim the ti...   Sep 24 2025, 09:54 AM
neyen14   I installed biral cylinders and had to trim the t...   Sep 24 2025, 10:27 AM
porschetub   I installed biral cylinders and had to trim the t...   Sep 26 2025, 11:29 PM
mate914   Wrong part?   Sep 24 2025, 06:46 PM
neyen14   Wrong part? That's what it seems like but I...   Sep 24 2025, 07:35 PM
wonkipop   Wrong part? That's what it seems like but ...   Sep 24 2025, 08:34 PM
914sgofast2   I would trim it so you get roughly the same amount...   Sep 24 2025, 06:55 PM
neyen14   I would trim it so you get roughly the same amoun...   Sep 24 2025, 07:37 PM
914sgofast2   If the trim rubs against the new cylinder barrels,...   Sep 24 2025, 06:57 PM
mate914   Nothing on the engine changed size with the 96mm j...   Sep 25 2025, 05:33 AM
neyen14   Nothing on the engine changed size with the 96mm ...   Sep 25 2025, 05:53 AM
mate914   Nothing on the engine changed size with the 96mm...   Sep 27 2025, 08:29 AM
emerygt350   Well, at least you have more fun surface. However...   Sep 26 2025, 06:09 PM
- Lo-Fi Version Time is now: 28th September 2025 - 05:22 PM
