neyen14 |
Member ![]() ![]() Group: Members Posts: 73 Joined: 2-December 07 From: New York Member No.: 8,408 Region Association: North East States ![]() |
I am using 96mm cylinders and the "vertical fin" of tin that goes behind behind the pushrods is hitting the cylinder....
What has anyone else that has had this issue done? Is there another tin option available for 96mm cylinders? How drastic will trimming it affect cooling? Thank you |
914sgofast2 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 769 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None ![]() |
I would trim it so you get roughly the same amount of top clearance between the tin and the cylinder barrels as you had/have with the old cast iron cylinder barrels. VW and Porsche knew what they were doing when it came to designing the cooling system of these Type 4 engines.
neyen14 |
I would trim it so you get roughly the same amount of top clearance between the tin and the cylinder barrels as you had/have with the old cast iron cylinder barrels. VW and Porsche knew what they were doing when it came to designing the cooling system of these Type 4 engines. Yes, I agree. Taking my time before measuring once and cut twice. Thx u |
Lo-Fi Version | Time is now: 28th September 2025 - 05:23 PM |
