> L jet on 2L heads, how to fit
rfinegan
post Sep 20 2025, 09:55 AM
How are people fitting the Ljet intake manifolds to work with 2.0L heads? FWIW this will be on my 2056.
914Sixer
post Sep 20 2025, 03:32 PM
Take the 1.8 runners and drill 3rd center hole. You should be able to bolt on 2.0 spacer block on and use it as a pattern for hole.
bdstone914
post Sep 25 2025, 06:53 AM
bdstone914
@914Sixer
' date='Sep 20 2025, 02:32 PM' post='3225008']
[/quote]
U don't think that will work. The two holes at the top are difference distances between 2.0 and 1.8 patterns.
rfinegan   L jet on 2L heads   Sep 20 2025, 09:55 AM
914werke   I used custom silicone connector hoses   Sep 20 2025, 10:41 AM
rfinegan   So you use the Djet runners on a Ljet plenum? SO i...   Sep 20 2025, 10:51 AM
Dave_Darling   You'd have to use the 2-liter runners. They...   Sep 20 2025, 03:09 PM
914Sixer   Take the 1.8 runners and drill 3rd center hole. Y...   Sep 20 2025, 03:32 PM
JamesM   Take the 1.8 runners and drill 3rd center hole. ...   Sep 20 2025, 07:14 PM
bdstone914   @[url=http://www.914world.com/bbs2/index.php?showu...   Sep 25 2025, 06:53 AM
TRP   Will you be running bigger injectors for the 2056?...   Sep 20 2025, 06:45 PM
JamesM   Find a 912e system :lol4: :lol4: :lol4: Serio...   Sep 20 2025, 07:13 PM
914werke   So you use the (2.0L) D-jet runners on a Ljet ple...   Sep 20 2025, 10:30 PM
GregAmy   Genuine curiosity: why? Rebuiliding a 1.8L with 2L...   Sep 21 2025, 06:26 AM
rfinegan   @GregAmy , This will be and after market EFI crank...   Sep 21 2025, 09:06 AM
rfinegan   Thanks every one for the intake tips....no more sy...   Sep 21 2025, 09:09 AM
914werke   In my case it was a 2056 that I fitted a GoWesty T...   Sep 21 2025, 11:46 AM
GregAmy   Good info...so it appears the LJet is the preferre...   Sep 21 2025, 03:30 PM
ClayPerrine   I have run L-Jet on a 2.0 engine. The runners are...   Sep 22 2025, 05:41 AM
JamesJ   I have run L-Jet on a 2.0 engine. The runners ar...   Nov 21 2025, 12:57 PM
rfinegan   Chat GTP 5 on throttle body size for 2056: Short v...   Sep 24 2025, 09:34 AM
Geezer914   I am running a 2056 with Ljet FI. Installed a 50m...   Sep 24 2025, 09:51 AM
JamesJ   I am running a 2056 with Ljet FI. Installed a 50...   Nov 22 2025, 07:22 AM
Geezer914   [quote name='Geezer914' post='3225523' date='Sep ...   Nov 23 2025, 09:39 AM
JamesJ   I am running a 2056 with Ljet FI. Installed a 50...   Nov 24 2025, 11:41 PM
rbzymek   I am running a 2056 with Ljet FI. Installed a 50...   Dec 5 2025, 08:58 AM
rfinegan   Thanks all for the insights and advice as i move i...   Sep 24 2025, 08:41 PM
914Sixer   Yep, that was all read pointed out, my bad.   Sep 25 2025, 06:57 AM
914werke   Here you go :) https://members.rennlist.com/demi...   Nov 22 2025, 02:44 PM
JamesJ   Thanks guys! Super helpful! Rob, we'l...   Nov 24 2025, 08:45 PM
rfinegan   PROGRESS: While I had the welder out for the O2 b...   Dec 30 2025, 01:38 PM
Geezer914   When I installed the modified 50mm Vanagon throttl...   Dec 31 2025, 09:37 AM
rfinegan   Geezer914, I plan on giving ^this^ a try once its ...   Dec 31 2025, 09:54 AM
- Lo-Fi Version Time is now: 12th March 2026 - 02:10 AM
