> 1974 wiring and fuel problems, need answer to the wiwing of fuel pump from relay board
Matthewk
post Sep 25 2025, 06:46 PM
Hello, I've been working on a 1974 914 for the past year. Ive rebuilt the motor since the last owner overheated it somehow (no compression). Ive put the motor back in and I cannot seem to remember where any of the small female ground connectors go from the wiring harness. Like the many different small ones in the transmission harness that goes into the engine bay. And the two near the distributor. I remember there being a ground connection under the intake but I dont know which ones go there. Ive been trying to read wiring diagram but I cant understand it what so ever because nothing is labeled. So I'm just guessing reading it.
My other question is, what do I do about the fuel pump not working. If you put power externally it works, but from the relay board it just has no power past it. The power supply relay clicks, but fuel pump does not. There was power to the fuel pump relay pins a couple days ago now there isn't. Maybe I'm just tweaking out. Last owner has a whole bunch of fuel pump related things highlighted in the book he gave me. My brother read that the relay board could go bad but I doubt it.
In another post, I read that you need to switch the 25 amp fuse for an 18. It solved someone else problem of blowing relays. Ive swapped relays around and they work in other spots. So it isn't bad relays.
Hopefully someone understand what I'm asking and has the solutions for it.
thx
JeffBowlsby
post Sep 26 2025, 06:02 PM
This diagram should answer all you questions: https://bowlsby.net/914/WiringHarnesses/doc...74-75_L-Jet.pdf
If not let me know.
Adding photos is easy, if you know rules. http://www.914world.com/bbs2/index.php?showtopic=13637
Matthewk
post Sep 26 2025, 06:33 PM
QUOTE(JeffBowlsby @ Sep 26 2025, 05:02 PM) *
If not let me know.
oh thx. can you send me a diagram for main harness too? Thank you!
- Lo-Fi Version Time is now: 19th March 2026 - 12:50 AM
