| Matthewk |
Sep 25 2025, 06:46 PM
Newbie ![]() Group: Members Posts: 4 Joined: 8-October 24 From: Washington state Member No.: 28,398 Region Association: Pacific Northwest |
Hello, I've been working on a 1974 914 for the past year. Ive rebuilt the motor since the last owner overheated it somehow (no compression). Ive put the motor back in and I cannot seem to remember where any of the small female ground connectors go from the wiring harness. Like the many different small ones in the transmission harness that goes into the engine bay. And the two near the distributor. I remember there being a ground connection under the intake but I dont know which ones go there. Ive been trying to read wiring diagram but I cant understand it what so ever because nothing is labeled. So I'm just guessing reading it.
My other question is, what do I do about the fuel pump not working. If you put power externally it works, but from the relay board it just has no power past it. The power supply relay clicks, but fuel pump does not. There was power to the fuel pump relay pins a couple days ago now there isn't. Maybe I'm just tweaking out. Last owner has a whole bunch of fuel pump related things highlighted in the book he gave me. My brother read that the relay board could go bad but I doubt it. In another post, I read that you need to switch the 25 amp fuse for an 18. It solved someone else problem of blowing relays. Ive swapped relays around and they work in other spots. So it isn't bad relays. Hopefully someone understand what I'm asking and has the solutions for it. thx |
| wonkipop |
Sep 26 2025, 09:03 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,460 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille
and if you are looking for a really good wiring diagram in color go here.
http://p914-6info.net/Manuals.htm you can download a copy of the factory workshop manual. the electrical chapter has the wiring diagrams for all the cars in different forms. will let you track and trace the quite different wiring for the fuel injection in the 1.8s. (IMG:style_emoticons/default/beerchug.gif) i had this photo lying around from another topic. dual relay is the gizmo doing a lot of the work controlling the f p. if its an original d r it will be silver in color. later update replacement d r is black plastic. |
Matthewk 1974 wiring and fuel problems Sep 25 2025, 06:46 PM
JeffBowlsby Help us help you!
Start by telling us what en... Sep 25 2025, 07:51 PM
Matthewk So, its a fully stock 1974 1.8L
https://ik.image... Sep 26 2025, 05:20 PM
JeffBowlsby This diagram should answer all you questions: htt... Sep 26 2025, 06:02 PM
Matthewk
This diagram should answer all you questions: ht... Sep 26 2025, 06:33 PM
JeffBowlsby All are here:
https://bowlsby.net/914/WiringHarne... Sep 26 2025, 06:38 PM
wonkipop
Hello, I've been working on a 1974 914 for th... Sep 26 2025, 06:55 PM
fiacra
Hello, I've been working on a 1974 914 for th... Sep 26 2025, 07:39 PM
Matthewk
Hello, I've been working on a 1974 914 for t... Mar 18 2026, 02:57 PM
Artfrombama
[quote name='fiacra' post='3225848' date='Sep 26 ... Mar 18 2026, 04:10 PM
wonkipop forgot to mention.
you can test the fuel pump is r... Sep 27 2025, 01:28 PM![]() ![]() |
Lo-Fi Version | Time is now: 19th March 2026 - 12:52 AM |
