neyen14 |
Member ![]() ![]() Group: Members Posts: 73 Joined: 2-December 07 From: New York Member No.: 8,408 Region Association: North East States ![]() |
I am using 96mm cylinders and the "vertical fin" of tin that goes behind behind the pushrods is hitting the cylinder....
What has anyone else that has had this issue done? Is there another tin option available for 96mm cylinders? How drastic will trimming it affect cooling? Thank you |
mate914 |
Matt ![]() ![]() ![]() Group: Members Posts: 900 Joined: 27-February 09 From: Eagles mere, PA Member No.: 10,102 Region Association: North East States ![]() ![]() |
Nothing on the engine changed size with the 96mm jugs.
Did you remove that baffle from a type 4 motor? Matt |
neyen14 |
Nothing on the engine changed size with the 96mm jugs. Did you remove that baffle from a type 4 motor? Matt Thx for the thought provoking help Matt.... it's the cylinders.... they're wider further down on the cylinder than the usuals. There's more fin surface area. Dang it.... I appreciate everyone's help |
mate914 |
Nothing on the engine changed size with the 96mm jugs. Did you remove that baffle from a type 4 motor? Matt Thx for the thought provoking help Matt.... it's the cylinders.... they're wider further down on the cylinder than the usuals. There's more fin surface area. Dang it.... I appreciate everyone's help I learned something new also. Glad you got the fix. Matt |
Lo-Fi Version | Time is now: 28th September 2025 - 05:23 PM |
