> O-ring oil pump, Picture needed
Chad911sc
post Sep 26 2025, 01:28 PM
So on my new 2056 I have been getting low oil pressure numbers after the oil gets hot. I have 85 lbs at start up, but after it gets to 220, I’m only getting 5lbs at idle and 45lbs at rev to around 5grand. I do have an external filter/fan combo that could be contributing to my issue. After it gets past 190 the valve opens up and lets the hot oil into the external fan cooler combo. I changed out the 26mm oil pump to the 30mm offered on LN engineering, but still same problem. The reason I ask about O-ringing my pump is because when I changed out the pump to the bigger one, I noticed that my case was gouged in 2 places where the pump press fits into the case. I’m thinking that this could be my culprit. That the oil is just pushing back into the sump from those digs in the case halves. I also ordered the piece from Tangerine racing to replace my oil valve spring inside the case, as I still am using the stock spring as of now. I’m going to pull the pump back out of the case this weekend and I will post a couple pics of the gouges in the case.
I was wanting to know exactly where this o-ring would go on the pump, so I can take it to my machine shop and have a grove beveled into it. One more thing out of the equation to solve this problem.
Jack Standz
post Sep 27 2025, 04:56 PM
QUOTE(Chad911sc @ Sep 28 2025, 04:03 AM) *
The pump had a pretty good leak from the gasket between the pump and the case, so I thought while I had it out, I would just put in a larger one due to the extra hose and cooler.
I guess I’ll find out in a week when I get the Tangerine part.
Interested to know if anyone has had good or bad reviews of the "Dual-O-Ring" Pro Pump
Only at Lowbugget.com! that Superhawk996 identified. Sounds like it might prevent oil leaks from the cover. Anyone used one?
(Have a couple of Gene Berg hard anodized type 1 oil pumps with O-rings in the pump bodies, but never used an oil pump with an o-ring on the cover).
https://www.lowbugget.com/oil_pump.html
3 User(s) are reading this topic (2 Guests and 0 Anonymous Users)
1 Members: cgnj
- Lo-Fi Version Time is now: 27th September 2025 - 07:19 PM
