ctc911ctc |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,221 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States ![]() ![]() |
914-6, 1970 - all original, good compression and leak down - was running very good prior to taking the engine out for gasket replacements and thorough cleaning.
All, Trying to get this car started - what would you suggest? For details as to what has been done up until now, please see this thread: http://www.914world.com/bbs2/index.php?sho...=373371&hl= Got the engine in, spilled gas and oil, forgot to tighten the drain plug.....and so it goes.... (IMG:style_emoticons/default/dry.gif) No oil or gas leaks (or no more) Got the engine cranking and assured that there was a spark - there is - and that each carb has gas - accel pumps are squirting and calibrated. Look good I watched a few times two videos on the topic https://www.youtube.com/watch?v=dwwMn1KxjqQ https://www.youtube.com/watch?v=LrGH9e52o1c Soo, It cranks, no galloping, Cylinder #5 is popping a few times.....nothing else, I did set the timing and the dwell, used the Position of the rotor at TDC to start the timing position. Just like the video above...... I Squirted both sides with a few pulls of the accelerator pumps and also opened the throttle and held it open. No Start. Did not want to over work the starter, what would you advise as my next moves? Thank you Teeners! |
Lo-Fi Version | Time is now: 1st October 2025 - 04:51 AM |
