| DC_neun_vierzehn |
Oct 9 2025, 10:47 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 591 Joined: 16-November 20 From: Coastal Delaware Member No.: 24,893 Region Association: MidAtlantic Region
'73 2.0 w/ original FI
Since I sprung a fuel leak in the engine bay, I've decided to replace all 4 injectors and replace ALL the rubber fuel hoses in the engine bay. I have no idea how old these items are and I'd rather have peace of mind with new hoses and injectors (vs. trying to skimp and deal with an engine fire). I order the replacement injectors (Standard Motor Products FJ67) that come with the rubber elbows. Now I need to order the rubber hose. Are ALL the rubber fuel hose lines in the engine bay the same size (7mm)? I don't see a precut kit on any of the usual 914 suppliers. I'm guessing I need to buy several meters of it and cut it myself. If so, how much do I need to order? I'm looking at this option, but I'm open to recommendations : ) https://www.autoatlanta.com/Porsche-7-Mm-Fu...N-RN202811.html |
| 914werke |
Oct 9 2025, 12:52 PM
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,447 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest
So this seems to be a good segue to advise of a item 914werke offers. (IMG:style_emoticons/default/rolleyes.gif)
I try not to overtly market in others threads but in this case it made sense (to me) So based on the descriptions provide by OP they are working on a D-Jet equipped (2.0L) motor. Wisely they have recognized that it is prudent to replace old fuel lines with new (ASTM D4806) lines that are resistant to Ethanol blends found in so may locations now. One design flaw I recognized with D-Jet equipped motors was the routing of a rubber line over the top of the motor from rail to rail. OG, that line was clad in a plastic sheath presumably to protect it. Nowadays you'd be hard pressed to find a car with that sheath still in place & if you did IT NEEDS its line replaced! Then reason this "design" is problematic is the top of the motor case is a very hot spot on the engine. With the OE routing you ARE inadvertently heating the fuel being fed to the injectors. 914werke offers a simple kit that solves this issue that reroutes that fuel line using a pre-bent, & flared SS line in front of the impeller housing. This location has the secondary benefits of being located in the stream of air being sucked into the Impeller, cooling the contained fuel rather than heating it & limiting the amount of perishable rubber in the engine bay! ![]() |
DC_neun_vierzehn Rubber fuel hoses in engine bay question Oct 9 2025, 10:47 AM
JeffBowlsby https://bowlsby.net/914/Classic/zTN_FI_Hose...ump_... Oct 9 2025, 10:51 AM
DC_neun_vierzehn
https://bowlsby.net/914/Classic/zTN_FI_Hose...ump... Oct 9 2025, 12:01 PM
DC_neun_vierzehn What brand and supplier are most people please wit... Oct 9 2025, 12:02 PM
wonkipop
So this seems to be a good segue to advise of a i... Oct 9 2025, 01:59 PM
bdstone914 @DC_neun_vierzehn
' date='Oct 9 2025, 09... Oct 9 2025, 01:02 PM
DC_neun_vierzehn
But a 25 foot roll of 5/16 (8mm) Gates Baracade l... Oct 10 2025, 04:07 PM
DC_neun_vierzehn I’m so glad I decided to replace all rubber fuel... Nov 6 2025, 06:32 PM
fixer34
I’m so glad I decided to replace all rubber fue... Nov 6 2025, 08:52 PM
DC_neun_vierzehn Ha. Good observation.
. Nov 7 2025, 06:23 AM![]() ![]() |
Lo-Fi Version | Time is now: 7th November 2025 - 09:31 PM |
